Old 11-16-2007, 03:18 PM   #1
Newbie need help setting up Street & strips
I been very frustrated for the past few day trying and searching for more info how to set S&S to work with RR. Can someone here kind enough walk me through this.
First: I have 2006 S&S with gps locator which S&S doesn't detected, it shown up in device manager on com 3 and I set the comport accordingly in S&S and hit the scan button, it shown no gps device found.
Second: How do I setup RR to work with S&S? In RR config I set the path to gps to where S&S installed, but when I hit the GPs button, it open up S&S app. I thought S&S was integrated in RR so I can use interface from RR. Please tell me what I did wrong. I used DF skin.
Thank You Everyone
Anchim
anchim is offline   Reply With Quote
Old 11-16-2007, 03:33 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
For #1, make sure you scan outside of RR or else it wont save the port. Also try plugging it in directly to the motherboard not to a usb hub.
For #2, that is how it works. It is "embedded" not integrated.
Old 11-16-2007, 04:58 PM   #3
Sounds like a porno.
Ampie Case
2.5" Hard Drive 80GB Toshiba 5400rpm
Kingston 512 MB DDR RAM PC3200
Xenarc 700TSV - VGA Monitor
VIA EPIA M10000 Mini-ITX Mainboard
M1-ATX 90 Watt - Smart Power Supply
2005 Honda Civic
Maheriano is offline   Reply With Quote
Old 11-16-2007, 09:22 PM   #4
Thanks for the comments. I did the setup for gps using S&S only not with RR. it has 3 ports, but after scanned, all 3 ports shown no gps device found. As for S&S, you mean RR run the S&S app then you control it from S&S not from RR gps embedded options.
Anchim
Next & Current Street Labels from iGuidance Blue ZX3 RR Plugins 42 11-14-2007 02:03 PM
does the street atlas delorme install drivers for gps reciever? Snortonnorton Software & Software Development 6 08-29-2007 03:26 PM
iGuidance Street names in RR (revisited) Shao128 Road Runner 1 08-08-2007 11:45 PM
Ipod not working with street deck. Francopacks StreetDeck Bug Reports 6 06-30-2007 10:02 AM
street names with a comma and invisible streets lez Map Monkey 0 03-03-2005 11:28 AM
