Old 11-22-2007, 07:57 PM   #1
HELP!!!!!! Earthmate LT-20 with microsoft mappoint/streetdeck
I am trying to use my Earthmate GPS LT-20 for streetdeck. i downloaded the third party software from delorme and the unit locks onto satellites and has a very good connection. when i try to set up mappoint to use the information obtained by this GPS reciever it says the COM port is available but no GPS info is being recieved. i have both set to the same COM port so thats not the problem. the unit is NMEA 2.0 compatible also. has anyone been successful in using a DeLorme GPS product with streetdeck or mappoint?
RobPfis07 is offline   Reply With Quote
Old 11-22-2007, 08:01 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
Is your DeLorme unit outputting NMEA data?
If it is not, you need to make that hapen for SD to do anything with it
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 11-22-2007, 08:29 PM   #3
yea it says it is outputting NMEA data, thats what i dont understand
Old 11-22-2007, 11:07 PM   #4
Check that the baud rate is correct
BIGGKATT01 is offline   Reply With Quote
Old 11-23-2007, 11:09 PM   #5
any suggestion on how to go about checking the baud rate? and what should it be set to once i find it? thank you
Old 11-24-2007, 05:51 AM   #6
Most GPS are set to 4800,N,8,1.
That's what my BU353 uses and operates flawlessly, however I would consult the manual for your Earthmate.
You need to set the COM port speed in the Device Manager. Set the COM port in the Nav preferences within StreetDeck.
Also, how did you verify the NMEA senteces output by your Earthmate?
You say that you know it's outputting NMEA, but how did you determine this?
My Worklog
Old 11-24-2007, 07:44 AM   #7
Marvin Hlavac's Avatar
Quote: Originally Posted by RobPfis07 View Post
... it says the COM port is available but no GPS info is being recieved ...
It is quite possible your setup is configured just fine, but the GPS receiver hasn't yet acquired a good satellite fix because you are indoor. Take it outside, give it several minutes to start working, etc ...
Marvin Hlavac is offline   Reply With Quote
Old 11-25-2007, 10:47 AM   #8
thank you all. i know that it is outputting NMEA because my GPS came with a small program to view the information. i set the output to NMEA. also, it has a little annoying light on it, but it is also very helpful. i have a lock, but Streetdeck/mappoint wont read the info. i will try what you said about going into device manager and all that. thanks a million.
Canīt get DirectX to work Linde Software & Software Development 0 10-19-2007 07:35 AM
SD crashes on startup mangus580 StreetDeck 7 10-05-2007 11:14 AM
TT Sirius USB interface Pyrotek General Hardware Discussion 0 09-08-2005 08:15 AM
