The MP3car.com Store
Thread Tools Display Modes
Old 11-25-2007, 04:17 PM   #1
FTWRUBI's Avatar
Vehicle: 03 Jeep Rubicon
My Photos: (3)
GPS offroad
what is the best tracking gps mapping software that you have experience with?
FTWRUBI is offline   Reply With Quote
Sponsored Links
Old 11-25-2007, 04:20 PM   #2
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
I forget the company that puts it out, but there is software that includes topographical maps as opposed to standard-issue roadmaps.
For off-roading, I would think these would be far more useful than roadmaps.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 11-25-2007, 05:33 PM   #3
wi77iam's Avatar
Vehicle: 2004 Subaru WRX STi
My Photos: (0)
DeLorme Topo.
wi77iam is offline   Reply With Quote
Old 11-25-2007, 05:46 PM   #4
NiSlo's CarPC Specs
NiSlo's Avatar
Vehicle: 06 Impreza Hatch
My Photos: (16)
Try Ozi Explorer
I installed my carpc into my pet Kangaroo, mate.
NiSlo is offline   Reply With Quote
Old 11-25-2007, 06:29 PM   #5
My Photos: (26)
I don't think that Ozi Explorer is going to do much good in Fort Worth, Texas, USA.
My Worklog
Old 11-25-2007, 06:35 PM   #6
NiSlo's CarPC Specs
NiSlo's Avatar
My Photos: (16)
I thought of that and checked the website before I posted. It appears that they have maps for much of the world here. Ironically, the University of Texas appears to have a miriad of maps compatible with Ozi Explorer here
Old 11-25-2007, 07:20 PM   #7
My Photos: (26)
I wasn't aware of that.
Pretty cool, actually....
Although the name Ozi Explorer is a bit of a misnomer, then, since it covers more than just Australia.
My Worklog
Old 11-25-2007, 07:31 PM   #8
FTWRUBI's Avatar
My Photos: (3)
I have the Delorme atlas already, So what would it be betwix Ozi and Delorme why would one be better than the other? Once I am on the trail, I am not going to have much time or stability to be pushing buttons or operate a touch screen. My Delorme has voice commands does the Ozi or De Topo?
Old 11-25-2007, 10:27 PM   #9
Vehicle: 2000 Toyota 4Runner
My Photos: (0)
I use Ozi Explorer and know several other people who also use it. I don't believe there is any voice command capability, but I don't remember hearing anyone say they needed voice commands. Usually, we just have Ozi running and watch the position on the screen. If you get to a junction and need to think about which way to go, just stop and use the touchscreen (7" diagonal screens are marginal for touchscreen use in my opinion - my 10.4" works OK with a stylus) or a mouse. I sometimes enter a route ahead of time so I can load that and just follow the colored line if there is anything particularly complex about the route.
There is a 3rd party utility called Travel Mate that has some voice output and I think it can record voice clips, but I don't think it has any voice commands either.
One thing Ozi Explorer can do is import maps in a lot of different formats. You can get the USGS topo maps and aerial photos from various places and use those for the US. It does take a bit of study to know how to import some of them though unless you get sets of maps from someone, so it isn't just load a file and it works without any effort.
You can also take a picture such as a .jpg image and import that and use it for navigation. You have to calibrate the image by putting in known coordinates of several points on the image which also takes a bit of work. You have to be able to determine the lat/lon info of some points like the 4 corners of the map. I've used that to import maps I've found on the web. As long as its in a format Ozi can work with (and there are a lot), just about anything can be used. I've even loaded state and county highway map images and calibrated them for use.
OziExplorer is NOT something I can advise trying to operate while driving down the highway unless you have a copilot. It wasn't set up for that. None of its controls are big enough to reliably use with a touchscreen and your finger unless you've got a HUGE screen. Its ok to use to check your position once running by glancing at the position indicator, but beyond that, let someone else run the program if needed or pull off the road.
Alanh is offline   Reply With Quote
Old 11-26-2007, 07:24 AM   #10
My Photos: (0)
Maptech
Same topo maps you would buy at an outfitter store
Mini Sumo Was Here
Mini Sumo is offline   Reply With Quote
Sponsored Links
Old 11-26-2007, 07:35 PM   #11
FTWRUBI's Avatar
My Photos: (3)
I tried to run Delorme on the Tablet today on the way to Miss. It sucked, the tabs were way to small and that was on a 14in touchscreen. The other thing that I noticed and remembered why I quit using it was the reciever kept loosing signal. The last time I used it was in the fog in Coastal La. No signal. I later bought a Garmin and it held onto the signal much better. Is there any other reciever's that hold on like a hungry wellfare mom?
Sponsored Links
vB code is On
Trackbacks are Off
How to setup iGuidance GPS for RoadRunner MatrixPC RR FAQ 27 07-08-2008 10:34 PM
PPC Car GPS and MP3 mini How To hotrod_nut General Hardware Discussion 1 02-25-2008 01:24 PM
MS Streets & Trips 2007 w/ GPS Locator EQNish GPS 3 08-10-2007 04:03 PM
few gps questions fuctup GPS 2 03-02-2005 01:40 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
