The MP3car.com Store
Thread Tools Display Modes
Old 11-28-2007, 12:16 AM   #1
jnthn205's CarPC Specs
My Photos: (0)
trouble with iguidance 3.0 and gu353 gps receiver
Ok so I just recently installed my carpc. I previously hooked up the carpc in my room with the GPS receiver hooked up and it found my house and everything.
Well I hook it up to my carpc in my car and now it can't find the signal. I have tried to locate it right on my dash, on the moon roof, most visible signal places and no finding.
Anyone know how to get this working? Is there a setting I have to set or something?
jnthn205 is offline   Reply With Quote
Sponsored Links
Old 11-28-2007, 12:25 AM   #2
PontiacGA's CarPC Specs
PontiacGA's Avatar
Vehicle: 2003 Pontiac Vibe GT/93 Pontiac Grand Am
My Photos: (0)
I just got mine working running just IG by itself. Make sure you have the GPS port set right in IG and keep the baud rate at 4800. Now, If I can only get it to run like this in RR/
Mike
My Rides:
'03 Vibe GT!
My AED GA!
PontiacGA is offline   Reply With Quote
Old 11-28-2007, 12:29 AM   #3
My Photos: (0)
Where do I go to get to the GPS settings, and how am I supposed to figure out the GPS port? Where do I import the baud rate at??
Old 11-28-2007, 12:33 AM   #4
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
iGuidance does it automatically. Select Auto from the GPS drop down menu up top. It will autoscan (like 30sec to 2min depedning on what all you have connected) and will say "found gps on COM # using 4800 and blah blah. Do this outside of RoadRunner, and then file-->exit then open it up embedded in RR. If you do this while embedded in RR, nothing will save.
Old 11-28-2007, 12:40 AM   #5
My Photos: (0)
holy cow, I just realized something. I have the resolution too high or something because when it is connected on the touchscreen in my car, it doesn't even show the file|tools|view menu. It just shows under that. Should I just lower or heighten the resolution in order to see it?
Old 11-28-2007, 12:43 AM   #6
2k1Toaster's Avatar
My Photos: (1)
you have it backwards.
If your screen is too small, your resolution is too low. Increase the resolution. And you arent in full screen mode are you? Does it actually go out of the screen area, or is there just nothing around it showing but you can still see viewable lcd around the window?
Old 11-28-2007, 01:24 AM   #7
PontiacGA's Avatar
My Photos: (0)
Any idea on how to get it to work in RR like it does running itself?
Mike
My Rides:
'03 Vibe GT!
My AED GA!
Old 11-28-2007, 05:28 AM   #8
My Photos: (0)
Yea, I just have to adjust the screen so it shows the file menu.
Old 11-28-2007, 11:06 AM   #9
PontiacGA's Avatar
My Photos: (0)
Update: Read how to fix this problem. Needed Xport com port splitter.
Mike
My Rides:
'03 Vibe GT!
My AED GA!
Old 11-28-2007, 01:53 PM   #10
My Photos: (0)
BIGGKATT01 is offline   Reply With Quote
Sponsored Links
Old 11-28-2007, 07:05 PM   #11
My Photos: (0)
I got the gps working. Drove around with it today for a little bit to test it out. It was nice. It also worked in road runner too which was a huge relief, seeing as all the problems I have been having.
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
