Old 12-03-2007, 06:46 AM   #1
Mapfactor Navigator 7 COM port Error
Hiya folks,
Hopefully someone can help me out.
I have just purchased Navigator 7 (version 7.1.25)
When I try to connect to the GPS com port manually I get the error that the application cannot connect to the GPS COM port.
If I use automatic connection then the port is found and all the status fields seem to start working correctly. However, when I press the "Turn on GPS" button, I again get the error that the application cannot connect to the GPS COM port.
I am using a VIA EPIA 800Mhz PC. and a Navilock USB GPS.
I have used Navigator 4, Destinator3 and Seaclear which all work fine with the GPS.
Also I use xport3 serial port emulator (to create virtual com ports), to simultaneously use multiple programs with the one GPS.
I have tried using Navigator 7 on its own (without xport3 active) and also in conjunction with xport3, but neither configuration has worked.
Can any of ye wonderkinds think of what I might be doing wrong as this is driving me crazy.
Thanks,
/Markie
markieb is offline   Reply With Quote
Old 12-12-2007, 05:41 AM   #2
Ok, Finally found the answer (no thanks to mapfactor who didn't even reply to my query)
It was a simple mistake in the end. When I was installing the software I set up the TMC device protocol for my Navilock GPS (which was of course listed in the SW). However,
my navilock doesn't support TMC and hence nothing worked at all. On I selected no TMC device everythin worked fine.
/Markieb
serial port to game port adapter wiring asif General Hardware Discussion 5 08-17-2006 05:47 PM
Error No.: -2147221187 cdevelasco MM Bugs 15 06-28-2005 08:03 AM
com port and invalid property error corsamel MM Bugs 0 03-03-2005 09:20 AM
Via Mini-ITX Epia 5000 serial port not working vash General Hardware Discussion 2 08-13-2002 09:48 PM
Spliting power on a PS/2 port... Defiler General Hardware Discussion 3 02-27-2002 04:02 PM
