12-21-2007, 09:26 AM
#17
Hello
I runnig this sygic drive and its exelent software, I only have poblem that I dont know how to setup that will run full screen. The problem is that I have to make extra comand -rfull to open in full screen. Can someon help me how to execute that when I press GPS button.
I am noob yes.
But I am fast learning
12-21-2007, 03:41 PM
#18
Thanks for the fullscreen command - works great. Still need maps for New Zealand if anyone can help.
How I implemented it was:
1) right click on drive.exe and create shortcut
2) right click on the shortcut and select properties
3) in the target box at -rfull to the end
How run the shortcut everythime you want to use the app. PS the icons in the menu don't scale so looks odd when running super high res.
12-22-2007, 08:03 AM
#19
I know how to make full screen but I want to doit with GPS button on the main screen, otherwise that button is non good so why should it be there if I run most aplication from APPS menu. I thot that there mybe is some command line in the script, but I am not a script guy
Sorry dont have new zealand.
12-27-2007, 04:29 AM
#20
Vehicle: 94/Toyota/Corolla 1.6GLI
Make an batch file : gpssygic.bat
put this lines to it :
start drive.exe -no-safety
exit
and set it in the RRconfig > it will works
Englishlessness :(
12-27-2007, 09:32 AM
#21
has anyone figured out a way to get it to run borderless (ie. no window borders)
I want to embed it into the Cave Live frontend but I can't get rid of the borders around the window.. the only way i've found it to set it full screen but then my frontend buttons sit over some of the Sygic window
12-28-2007, 04:39 AM
#22
no, in RR it works right, set up the app name in CaVe
Englishlessness :(
12-29-2007, 05:20 PM
#24
Quote: Originally Posted by justintime
I cannot believe this software Sygic Drive v7 has not gotten more attention in this forums. I downloaded a demo, and it is absolutely stunning! Perfect for CarPC!!!
We need US MAPS!
The Sygic Drive USA/Canada maps are just around the corner
12-30-2007, 06:46 AM
#25
Anyone got any ideas how i can set the window size as default.
Im trying to use the Cfig plugin in centrafuse and use this sat nav, but its not embedding properly...as its too small. any ideas?
12-30-2007, 07:30 AM
#26
Raw Wave
Vehicle: 2002 Honda CR-V
Yes, you create a shortcut, and add these properties:
(taken from solocarputer.com forum)
r is the size, p is the position.
12-30-2007, 06:22 PM
#27
I tried this today. It's fantastic. I've also integrated speed cameras with voice alerting into it. They seem to work ok but I'll test them on the road tomorrow.
01-02-2008, 02:30 PM
#28
Vehicle: Audi S4
I tried this software and it looks promising but I have a problem connecting to my GPS port.
I tried to autodetect it but it fails with "GPS port not found" when I tried to define a port it fails with "opening failed, checkout your settings".
Anyone have had any luck with opening a connection to the GPS?
Failure is not an option...
01-02-2008, 03:15 PM
#29
create a folder in the install dir like so
drivers\default
copy Device.dll and Driver.dll in there. Then try it.
01-02-2008, 04:00 PM
#30
Vehicle: Audi S4
Hmm... This worked on my desktop, I could now select the comport from a list but for some kind of reason it doesnt work on the laptop that I'm using in my car. They are both running WinXP.
| Thread Tools |
| Display Modes |
Linear Mode
