The MP3car.com Store
Thread Tools Display Modes
Old 01-02-2008, 04:15 PM   #31
Beezer's CarPC Specs
Beezer's Avatar
My Photos: (0)
Quote: Originally Posted by Borte View Post
Hmm... This worked on my desktop, I could now select the comport from a list but for some kind of reason it doesnt work on the laptop that I'm using in my car. They are both running WinXP.
Remove the 2 driver lines from settings.ini so it looks like so....
[Drivers]
[WorldClock_Zones]
And remove settings.dat
Beezer is offline   Reply With Quote
Sponsored Links
Old 01-02-2008, 04:26 PM   #32
Borte's Avatar
Vehicle: Audi S4
My Photos: (0)
[Drivers]
[WorldClock_Zones]
This did the trick. Thank you for all your help Beezer!
Failure is not an option...
Borte is offline   Reply With Quote
Old 01-06-2008, 04:48 AM   #33
My Photos: (0)
I managed to embed the software into the Cfig plugin in centrafuse, and I can make it resize how it needs to....but the position doesnt change. doesnt matter what I set the position to.....it still cuts the top off the embedded sygic application.
Anyone got any ideas?
astrapc is offline   Reply With Quote
Old 01-06-2008, 05:13 AM   #34
My Photos: (0)
sorry, solved that now, only thing i need to know is how i can input the camera locations available for the uk, into the software from the spreadsheet on the freedrive website???
If anyone can tell me that - i'll be flying!!!
Old 01-06-2008, 05:53 AM   #35
My Photos: (12)
Not sure how you can do it from the spreadsheet on freedrive, but if you get the tomtom speedcam files and use a program called OV2UPI Translator 2.1 (google it) then you can covert them to the correct format for this program.
swift_gti is offline   Reply With Quote
Old 01-06-2008, 09:11 AM   #36
My Photos: (0)
and what function, or what setting points the nav program to the database once converted?
Old 01-06-2008, 09:13 AM   #37
My Photos: (12)
You just have to drop the converted POI's into your map folder (the UPI files) and then from inside the Sygic drive menu you can turn them on (Menu, Manage POI)
Old 01-06-2008, 11:02 AM   #38
Raw Wave
justintime's Avatar
Vehicle: 2002 Honda CR-V
My Photos: (0)
you guys found a USA map for Sygic?
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
justintime is offline   Reply With Quote
Old 01-06-2008, 02:46 PM   #39
Beezer's Avatar
My Photos: (0)
Thats how I done it, using the Tom Tom files from PocketGPS. It probably wouldn't be right for me to post the files here but I will post a howto instead.
1) Get PocketGPS speed cameras for Tom Tom. I got the November 2007 release. The files should be .ov2 files, one for each camera type, e.g
pocketgps_uk_gatso_20.ov2
pocketgps_uk_gatso_30.ov2
pocketgps_uk_gatso_40.ov2
.... etc etc
Make sure that you have the equivalent logos in bmp format for the files. e.g.
.... etc etc
4) run ov2upi, but run it for each ov2 file individually. I found that it didn't work properly when you told it to convert an entire directory at once.
5) You should have lots of upi files now.
pocketgps_uk_gatso_20.upi
pocketgps_uk_gatso_30.upi
pocketgps_uk_gatso_40.upi
.... etc etc
Rename these to whatever you want to appear inside Sygic Drive. e.g. I named mine
Fixed Speed Camera @ 20.upi
Fixed Speed Camera @ 30.upi
Fixed Speed Camera @ 40.upi
.... etc etc
6) Copy these upi files into your map directory e.g. GBR. Don't copy default.upi
7) Copy all bmp files into the Icons directory in Sygic Drive. Don't rename them. IIRC a few don't display properly so you have to load them into Irfanview or something & increase their colours to 8bit.
8) If you load up Sygic Drive now, you should see new categories in your POI management. You should see them named however you named the file & you should see an icon to the left of the name. If you enable them & look at the map, you should see the icon on the map.
9) If you want alerting as you approach a camera, you have to do the following...
10) copy wav files into the Sounds directory for your alerts. Get these from wherever you fancy. Personally, I used the ones from GatsohunterRR which in turn were borrowed from FreeDrive.
11) Edit SKIN/application.skin. USE NOTEPAD NOT WORDPAD. search for "managePOI.alarm". You should see 3 lists. items, sounds & icons. You need to add new items referencing the sounds that you added using a default icon. You can't add your own icons. Make up the name for the item for now - anything you want. e.g. here's mine
<listBox id="listBox.managePOI.selectSound" bitmapSound="_b.checkOff"
items="
managePOI.alarm
managePOI.alarm
managePOI.alarm
managePOI.alarm
managePOI.ring
managePOI.ring
managePOI.ring
managePOI.beep
managePOI.beep
managePOI.beep
managePOI.cam30
managePOI.cam40
managePOI.cam50
managePOI.cam60
managePOI.cam70
managePOI.camera
managePOI.mobile
managePOI.redlight
managePOI.speed"
sounds="
Sounds\Beep.wav
Sounds\Beep2.wav
Sounds\Beep3.wav
Sounds\Beep4.wav
Sounds\Bell.wav
Sounds\Phone.wav
Sounds\Ring.wav
Sounds\Whistle.wav
Sounds\Beep2.wav
Sounds\Alarm2.wav
Sounds\cam30.wav
Sounds\cam40.wav
Sounds\cam50.wav
Sounds\cam60.wav
Sounds\cam70.wav
Sounds\Camera.wav
Sounds\mobile.wav
Sounds\redlight.wav
Sounds\speed.wav"
icons="
_i.alertBeep
_i.alertBeep
_i.alertBeep
_i.alertBeep
_i.alertRing
_i.alertRing
_i.alertRing
_i.alertAlarm
_i.alertAlarm
_i.alertBeep
_i.alertAlarm
_i.alertAlarm
_i.alertAlarm
_i.alertAlarm
_i.alertAlarm
_i.alertAlarm
_i.alertAlarm
_i.alertAlarm
_i.alertAlarm
Save it
12) Edit SKIN/English.lang (or whatever your lang is). USE NOTEPAD NOT WORDPAD
Search for <lang id="managePOI.beep" text="Beep"/> Copy that line & add your new items as you want them to appear in the menu using the names you chose in the previous step.
e.g. here's mine
<lang id="managePOI.cam30" text="Speed Camera @ 30"/>
<lang id="managePOI.cam40" text="Speed Camera @ 40"/>
<lang id="managePOI.cam50" text="Speed Camera @ 50"/>
<lang id="managePOI.cam60" text="Speed Camera @ 60"/>
<lang id="managePOI.cam70" text="Speed Camera @ 70"/>
<lang id="managePOI.camera" text="Camera"/>
<lang id="managePOI.mobile" text="Mobile Speed Camera"/>
<lang id="managePOI.redlight" text="Redlight Camera"/>
<lang id="managePOI.speed" text="Speed Camera"/>
13) Load Sygic Drive, go to the Manage POI section & add an alert for your speed cameras. The alert sounds menu should now show the new items you entered.
Old 01-06-2008, 04:54 PM   #40
My Photos: (0)
forgive my stupidity.....poi converter doesnt offer a .upi file extension to save siles as?
And the ov2upi translator software gives error initialising when i try to open it?
Anyone able to assist me?
Sponsored Links
Old 01-06-2008, 05:02 PM   #41
Beezer's Avatar
My Photos: (0)
Apologies. I never could get poiconverter to work properly. I've now corrected the post above.
What error do you get on ov2upi?
Old 01-07-2008, 03:25 AM   #42
My Photos: (0)
when i double-click the exe (the only file to launch) it just says failed to initialise???
Old 01-07-2008, 08:33 AM   #43
The Vauxhall Vectra Project
ccsnet's CarPC Specs
ccsnet's Avatar
Vehicle: Vauxhall Vectra C SRI XPack Auto - v5 ( Via 12000 based ) Sygic & With FreeICE
My Photos: (0)
.... etc etc
.... etc etc
.... etc etc
.... etc etc
items="
managePOI.alarm
managePOI.alarm
managePOI.alarm
managePOI.alarm
managePOI.ring
managePOI.ring
managePOI.ring
managePOI.beep
managePOI.beep
managePOI.beep
managePOI.cam30
managePOI.cam40
managePOI.cam50
managePOI.cam60
managePOI.cam70
managePOI.camera
managePOI.mobile
managePOI.redlight
managePOI.speed"
sounds="
Sounds\Beep.wav
Sounds\Beep2.wav
Sounds\Beep3.wav
Sounds\Beep4.wav
Sounds\Bell.wav
Sounds\Phone.wav
Sounds\Ring.wav
Sounds\Whistle.wav
Sounds\Beep2.wav
Sounds\Alarm2.wav
Sounds\cam30.wav
Sounds\cam40.wav
Sounds\cam50.wav
Sounds\cam60.wav
Sounds\cam70.wav
Sounds\Camera.wav
Sounds\mobile.wav
Sounds\redlight.wav
Sounds\speed.wav"
icons="
_i.alertBeep
_i.alertBeep
_i.alertBeep
_i.alertBeep
_i.alertRing
_i.alertRing
_i.alertRing
_i.alertAlarm
_i.alertAlarm
_i.alertBeep
_i.alertAlarm
_i.alertAlarm
_i.alertAlarm
_i.alertAlarm
_i.alertAlarm
_i.alertAlarm
_i.alertAlarm
_i.alertAlarm
_i.alertAlarm
Save it
e.g. here's mine
I wonder if using the above process if its possible to add Uk traffic too using my Traffic System that RT put together on DC....
http://www.traffic.letscommunicate.c..._downloads.php
Terran
ccsnet is offline   Reply With Quote
Old 01-07-2008, 08:41 AM   #44
Beezer's Avatar
My Photos: (0)
Of course, you could even automate it, however, I'm not sure if you can update the POI file at the same time that Sygic Drive is using it. IIRC, Sygic Drive can avoid certain POI.
How often do you update the Traffic System POI file?
Old 01-07-2008, 08:56 AM   #45
ccsnet's Avatar
My Photos: (0)
Every three or five mins.... its live.
I was thinking you could automate it as POIEdit can be ran from a command line.....
Terran
Sponsored Links
vB code is On
Trackbacks are Off
Hard Drive Issues in a Vehicle Computer DarquePervert The FAQ Emporium 25 02-23-2008 01:35 PM
Western Digital buyers beware! tj!2k4 General Hardware Discussion 65 11-26-2005 12:17 AM
If im having the pc in the boot, how do i get the cables to the dvd drive in the dash philb General Hardware Discussion 6 04-07-2005 09:15 AM
FS: PC cards: video, audio, network; CD drive BriCubz Classified Archive 7 08-28-2004 12:12 PM
Connecting a PC hard drive to laptop? Yuriy General Hardware Discussion 28 07-01-2004 09:49 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
