The MP3car.com Store
Thread Tools Display Modes
Old 01-13-2008, 12:44 AM   #76
My Photos: (0)
FWIW: Audacity partially opens the .pak files (i.e. audio is fine, but appears cut short).
pokki is offline   Reply With Quote
Sponsored Links
Old 01-14-2008, 12:53 PM   #77
Vehicle: Citroen Xsara 2,0 16V VTS
My Photos: (0)
So has anyone found the TMC menu's in the software, or is that not supported, someone suggested that it could be enabled as a menu, but not if it actually works. I just got my new TMC/USB gps today and would love to test it.
Transflective Lilliput 8", LV-677DC Core Duo 1,83Ghz, , Mpegbox uSDC20D, Shuttle Express, HQCT, PG XS6600 http://carpc.boyakasha.dk
_dopehead_ is offline   Reply With Quote
Old 01-14-2008, 03:15 PM   #78
GTO
GTO's Avatar
Vehicle: 1992 Mitsubishi GTO
My Photos: (0)
Could someone please explain (to a noob) how to get this embedded in RR.
I keep on getting IE coming up.
Thanks.
GTO is offline   Reply With Quote
Old 01-14-2008, 03:38 PM   #79
Raw Wave
Laidback's Avatar
Vehicle: Jeep GC
My Photos: (0)
Thanks.
Don't have IE open on a page with Sygic Drive in the title bar, such as this one!
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 01-14-2008, 04:00 PM   #80
GTO
GTO's Avatar
My Photos: (0)
I don't get IE now, but I don't get Drive either.
Thanks for the help.
Sponsored Links
Old 01-14-2008, 04:26 PM   #81
Raw Wave
Laidback's Avatar
Vehicle: Jeep GC
My Photos: (0)
http://www.mp3car.com/vbulletin/1164101-post70.html
Laidback
Laidback Carputer
Old 01-15-2008, 09:38 AM   #82
GTO
GTO's Avatar
My Photos: (0)
Thanks but as I know nothing about skinning, skins or how they work that really means nothing to me.
Old 01-15-2008, 09:53 AM   #83
My Photos: (0)
I would encourage you to read the general embedding faq in the RR forum instead, theres alot of great info there, that you can use not only for this GPS part, but also for other applications you wan't to embed.
Old 01-16-2008, 05:57 AM   #84
GTO
GTO's Avatar
My Photos: (0)
Thanks, I'll do some more reading up.
My main problem is that I can get it to embed in RR but not resize. If I put anything after "C:\Program Files\Drive_XP\Drive.exe" it won't start up in RR.
Old 01-16-2008, 07:58 AM   #85
Tissy's CarPC Specs
Tissy's Avatar
Vehicle: Subaru Impreza 2005
My Photos: (0)
I can help you there i had a similar problem.
If you are loading Sygic off of a button, the COMMAND properties of this button should read:
"LOAD;sygic.skin;!Sygic DRIVE;C:\Program Files\DRIVE_XP\drive.exe |-no-safety -r800x520;!Sygic DRIVE||ACTIVATE;Sygic DRIVE"
Your best bet is to copy and paste exactly as i have done above (obvioulsy changing any of the necessary file paths you require).
The r800x520 is the dimesnions of the SYGIC application, so again you can change these to your liking.
I made a simple sygic.skin which looks like this:
MEDIACAR Skin
MEDIACAR IGUIDANCE. Skin
/, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
L04,309,31,74,35,255,102,0,18,"Digital Readout Thick Upright:B","REMAININGTRACKTIME",
L01,9,31,287,35,255,102,0,18,"Digital Readout Thick Upright:B","TAGARTIST||= - ||TAGTITLE||=","SCROLL-LEFT"
/, B, x, y, w, h, Command;COMMANDCODES, Tooltip
/, A, x, y, w, h, color R;RGB, G, B
A01,0,77,800,520,255,255,255
END
Hope this helps
System - Epia SP13000 for Main PC, Holux GR-213 USB GPS Receiver SiRF Star III, 2.4Ghz Uplink with VNC and Custom designed USB Intelligent SDC (In DEV). All fed to a Sony CDX-F7500 Headunit via USB. www.wrx-carpc.co.uk
Tissy is offline   Reply With Quote
Old 01-16-2008, 12:08 PM   #86
Raw Wave
Laidback's Avatar
Vehicle: Jeep GC
My Photos: (0)
Try it like this - C:\Program Files\Drive_XP\Drive.exe " " r800x600 p50x10 s
If that doesn't work then there is somewhere in RR GPS config that you can add options, I don't use RR but I've seen someone mention it before. Search the RR sub forum, there is a FAQ!
Laidback
Laidback Carputer
Old 01-17-2008, 04:46 AM   #87
My Photos: (0)
does anybody know if i can use keyboard shortcuts (page up or down) to change the zoom level in sygic.
the buttons on the sygic screen are too small for touchscreen usage and the zoom level does not change very visible, i.e. clicking three or four times on - button really brings you a different view of the map.
i then would like a road runner screen button with, let's say threy keystrokes, to zoom in / out. i know how to assign buttons in the EXECTBL.ini.
thank you
upspace is offline   Reply With Quote
Old 01-17-2008, 04:49 AM   #88
My Photos: (0)
another question sygic related:
i am often listening very loud (bass) music during driving. if then the voice jumps in, it almost blows my ears (and loudspeakers). you can easily listen techno and rap at high volumes but voices only tend to distort.
is there a way to have voice commands to be outputted at 50% of the current music volume (interrupting/pausing the music) and then resume full power music playback?
Old 01-17-2008, 05:46 AM   #89
GTO
GTO's Avatar
My Photos: (0)
Thanks Laidback that worked.
And thanks to Tissy for your time.
Old 01-17-2008, 02:11 PM   #90
My Photos: (0)
question/remark number three and four:-)
1. i notice a small lag from my current real position and the arrow of the car on the map. it is about 5-10 meters and is especially ugly when you are about to turn. let's say i do a left turn, sygic drive then seems to continue straigth for 1 or 2 secs, means not following the own proposed route and then jumps back into my left turn. most of the time the map is also oriented wrongly then, i.e. 90 degrees. am i clear? who noticed the same behaviour? it is very confusing, especially if you don't know the area, do a turn as proposed, want to double-check on the map and then sygic shows you something else. i already lost orientation with this many times. iguidance is never doing this. well it also does less smooth moving of cards. but what does it give to me if i have smooth animation but unclear orientation. i expect sygic to "interpolate" in first hand that i follow its instructions and scrolls the map the way the route goes and not just going straitgh.
2. sygic drive does calculate its routes in general well but i realized that it tries to guide you often through clearly marked pedestrian areas? is this due to the map material (doubt since it is teleatlas which is used for many other navigation systems) or does their routing procedure not taking care of it?
Sponsored Links
vB code is On
Trackbacks are Off
Hard Drive Issues in a Vehicle Computer DarquePervert The FAQ Emporium 25 02-23-2008 01:35 PM
Western Digital buyers beware! tj!2k4 General Hardware Discussion 65 11-26-2005 12:17 AM
If im having the pc in the boot, how do i get the cables to the dvd drive in the dash philb General Hardware Discussion 6 04-07-2005 09:15 AM
FS: PC cards: video, audio, network; CD drive BriCubz Classified Archive 7 08-28-2004 12:12 PM
Connecting a PC hard drive to laptop? Yuriy General Hardware Discussion 28 07-01-2004 09:49 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
