02-21-2008, 08:56 AM
#106
Quote: Originally Posted by Laidback
How? I can't get past this line
It gets to there opens sygic drive but then doesn't continue with the code.  I must have something wrong cause I don't really know .net.
I have the same problem, i can start DRIVE in my windows form application, but it stops after DRIVE is being started ... did you manage to execute the rest of your code?
I want to use methods of the SDK, but without this initialization, i can't ...
02-21-2008, 10:39 AM
#107
Raw Wave
Vehicle: Jeep GC
Yeah, use a version other than the demo
02-21-2008, 05:14 PM
#108
i use a DRIVE license, that's not a solution
02-21-2008, 07:05 PM
#109
Vehicle: BMW 320D M-Sport
Anyone got any good links to buy licence for uk version? how much is licence?
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
02-21-2008, 07:06 PM
#110
Raw Wave
Vehicle: Jeep GC
But which version are you using?
02-22-2008, 01:31 AM
#111
i use Sygic DRIVE version 7.198 with a french map
02-22-2008, 02:01 AM
#112
Raw Wave
Vehicle: Jeep GC
Beats me then, the SDK only doesn't work with v7 demo for me, all other versions and it's ok. Show what code you're using?
02-25-2008, 11:33 AM
#113
Vehicle: 1986/Volvo/740
Ok this software looks really really good tbh... I'm just wondering where to get it, and with scandinavian maps... tried the demo posted here earlier but without the Swedish maps I can't really get a idea how good it's working!
03-25-2008, 12:48 PM
#114
Vehicle: Citroen Xsara 2,0 16V VTS
So is anyone else having problems with drive.exe not being stopped properly when you exit RR ?
Also using the Exit button on the Skin, calling the EXIT function, does not seem to close it properly, the GUI is gone, but it is still in the process list in windows, and then i can't execute it again from RR until i reboot or manually kill the process in windows.
Transflective Lilliput 8", LV-677DC Core Duo 1,83Ghz, , Mpegbox uSDC20D, Shuttle Express, HQCT, PG XS6600 http://carpc.boyakasha.dk
03-25-2008, 12:50 PM
#115
Sorry about that last post, i forgot there is an option to do this in RR :-)
03-25-2008, 12:51 PM
#116
BTW, is everyone happy with the way sygic works, anybody doing some fun stuff integrating it closer to RR ?
05-05-2008, 07:24 PM
#117
anyone know long the demo is for?
Edit: Never mind solved now
CarPuter Progress:
05-06-2008, 12:47 PM
#118
Sygic is CPU hungry for low end system.
05-11-2008, 05:12 AM
#119
I really like it, when i figured out how they categorize the addresses where i live it got a lot easier to find stuff in there. I have my fps set at 30 now, it runs very smooth...i haven't checked cpu util when its running, but i never lags on my 1,8G core duo.
05-11-2008, 11:41 AM
#120
I think it's one of the best ive seen, big step up from Pc Navigator 7  which we were also using last year!
Only moans I have from 7.5.229 are:
1. The arrow always wants to go off road
2. The routing seems to want to go through very strange places, but it does get you there using the q1 2008 maps.
3. It uses alot of processor no route= 40% cpu with everything running, routing its usually around the 90-100% mark (sometimes goes under that)
4. Speed warnings dont match the roads ie: 60mph showing in a 30 zone, and 30 showing in a 70 zone
5. No post code search, seems to be working in the 7.0 demo version with the GB postcode file at the route of the map folder
Other than that its fantastic!
Be interesting to see if we can get any results out of tweaking the frame rate and memory usage from the settings.ini to see if it makes any performance improvements:
Code:
Application]
title=Sygic DRIVE 3ppc.net edition
name=Sygic
version=704400
; maximum number of screen refresh per second (in navigation view)
fps=25.0
; use memory=low if the device has very limited amount of program memory
memory=high
voiceAlphanumeric=alphanumeric.pak
voiceMenu=menu.pak
voiceNavigation=navigation.pak
swVersion=7.50.229
CarPuter Progress:
| Thread Tools |
| Display Modes |
Linear Mode
