I am trying to use xport3 and when i try to enable the ports I get a pop up with error 1275 driver ?
I have the main port on 3 and it is displaying info on the bottom of the window. I have ports 6 and 9 selected.
The only thing i can think of is that I am running xp 64 bit....
aahhhh I kind of thought so. do you think that there could be a solution, or should I try a different program. I used Xport on my last system and it worked great everytime....
Yeah, sometimes a 32 bit driver will work on one 64 bit system and not on another. I don't have anything 64 bit, so I can't build or test here. GpsGate may have a 64 bit version. That's all I can think of.
__________________ XPort 1.24 -GPS port splitter, logger, and USB device resume fix
just a small update,
I tried acouple of different drivers with no luck. I ended up installing xp 32bit, everything works great now. The machine seems alittle slower now, but I rather have things work right...
Thanks for you input
brian
