Old 12-19-2007, 12:03 AM   #1
VettePC's Avatar
iGuidance 3 Forgets Port!
Anyone have this issue? Iguidance 3 reverts back to COM1 everytime I close and re-open the program.. well, sometimes it doesnt loose it. What causes this? Using RR & DigitalFX 2.5 skin. Have Xport running split to COM 16 & 17. GPS receiver is on COM3. Set RR GPS to COM 17 (GPS STATS works every time i open it in DigitalFX. If I run Iguidance standalone and select port 16 it runs fine. Then close it and start RR and usually it will work. After closing RR and re-open Iguidance alone or through RR it is reverted back to COM1!
What causes this!?
VettePC is offline   Reply With Quote
Old 12-19-2007, 12:15 AM   #2
Fusion Brain Creator
2k1Toaster's Avatar
iGuidance doesnt like over COM9.
Also make sure you are doing your com scan outside of RoadRunner. So open iG from the start menu, scan, save, file-->exit, then launch roadrunner.
Old 12-19-2007, 06:49 AM   #3
just do what I did, make a batch file to import a registry entry to keep changing the port back everytime you start Iguidance. since all of my ports below 10 were taken.. I had to do this to get it to stay.
marcux is offline   Reply With Quote
Old 12-19-2007, 07:55 AM   #4
VettePC's Avatar
Oh, wow. Ok thanks! I know how to do the batch file/reg chnage, but how do you do this each time you start iguidance?
Thanks!
I'll try it tonight
Old 12-19-2007, 08:08 AM   #5
turn off ewf LOL
then reboot
set settings file or open iguidance, choose port, and exit the program properly
then, once done, turn back ewf
tracker64 is offline   Reply With Quote
Old 12-25-2007, 12:02 PM   #6
If possible, before using reg hacks and so on, try to set your GPS port below 8. Go to Device Manager, find your GPS receiver COM port, double-click, go to properties (I think, I'm doing this by memory), find the place where you can adjust 2 sliders (UART 16550-related), there should be a box at the bottom of that dialog box where you can choose the COM port. See if you can set it to something REALLY low, like 2, 3, etc. If you can, iGuidance will stop messing around. I used to have this problem for like a year until I blew a fuse (in my head), posted a message here, and someone just said "drop the COM port"
Doko ni datte, hito wa tsunagatte iru...
My Subaru Impreza install (now fully RAAMmatted!)
Realtime audio freestyle hiphop battles online - www.letsbeef.com!
Make beats? Know Rockwilder? Battle him! www.rocbattle.com.
Pseudo Nim is offline   Reply With Quote
USB port power dies?! pixelflash General Hardware Discussion 1 10-22-2007 09:26 AM
RR - iGuidance 3.0 embedding – Solutions Consolidated. EricE GPS 12 03-21-2007 10:34 AM
iGuidance SDK Quattro GPS 57 06-23-2006 07:37 AM
SDK commands over the serial port ???? tolisn Road Runner 4 12-14-2005 12:03 PM
Help with iGuidance v2.1, please.. and my opinion comparing it to Garmin nRoute ToNg GPS 2 08-18-2005 11:15 PM
