Old 10-28-2002, 04:42 PM   #1
Registered User
felix99's Avatar
Question GPS DATA on HD44780 char Display ??
2 question post
1.)
Any soft around to display GPS data on a HD44780 display ?
Like speed over ground , course and actual position - perhaps qth locator 4 HAM radio? ?
I think it's not diffucult to make but i don't have the knowledge in programming and actually not the time - ( exams are near again )
Why I want this?
Becuase when i do shorter trips I don't want to put my TFT screen every time but having speed an such displayed would be cool.
2.) Any interface circuit to connect a serial GPS directly to a hd44780 char LCD? I think it would be grat for example for me when I do trips on boat or walking in the mountains -
GPS=>###circuit##=>LCD -
Lcd and circuits in a box with a battery to get 5V and it would give a portable GPS for low money ! wouldn't this be cool?
Any ideas for such a circuit ?
I saw one here ( its in german but you could klook at the shematic diagramm) http://www.kh-gps.de/lcddisp.htm
But its made for a 16x2 LCD and I want it for a 16x4 or 20x4.
Because so it could display more data t one time .
( Yes I know about the Microprocessor GPS and LCD thread but it drives a serail one if i remember)
comments, suggestions ,questions??
Regards
Felix
( Yes I'm a crazy freak ! )
=>> Carpc Version2 -- Epia M 10K based<<=
::Epia M10k,7"VGA/40GB2.5",GPS,Opus90W ::
::trying to build second low cost carpc::
::Automp3.de :: CAR= Renault Clio2 - 2 seats 1.9D
felix99 is offline   Reply With Quote
Advertisement Sponsored links
Old 10-29-2002, 05:06 PM   #2
"GPS REPEATER displays NMEA-0183 data from a GPS, battery voltages, etc".
That link points to the description. The main page is http://www.vermontficks.org/pic.htm, which gives the source code and schematic as well. It uses a PIC16F876, and the author says he sells them preprogrammed if you don't have a PIC programmer.
djmjr is offline   Reply With Quote
Old 11-13-2002, 05:17 PM   #3
Skippman's Avatar
That's an interesting piece of equipment. But that doesn't do what I want.
I'm looking to take NEMA standard and output it from the PC to a character display. I'd like it to show lat/long and direction. That way, even when the GPS software is minimized I can still tell which way I'm going.
Stereo:Alpine IVA-D900 Head Unit | Alpine PXA-H510 DSP | Boston Pro Component Speakers Upfront | Boston Rally Rear Speakers | 2 Polk 10" Subs in the Trunk | Phoenix Gold Ti900.7 Amp
Skippman is offline   Reply With Quote
Old 11-13-2002, 05:42 PM   #4
Yeah, that sounds about like what I want too.
long/lat & direction would be really nice.
Of course I'll have to get a new GPS [grumble]fraggin earthmate[/grumble]
aka Kumaneko
"Don't make me moderate your ***!"
Maxima of Doom - project thread - photo gallery
mp3car system is currently FUBAR and finances do not allow for a correction of that situation
Real computer hackers use a rotary cutting tool on their motherboard.
ShinkunoNamida is offline   Reply With Quote
Old 11-25-2002, 06:05 AM   #5
what's wrong with your earthmate?
IN DEVELOPMENT -- '96 Mustang, lilliput with PII/450 laptop, custom DC-DC power supply, 60GB; Garmin GPS; 802.11g; compact keyboard, small graphical LCDs, OBDII.
Telek is offline   Reply With Quote
Old 11-25-2002, 02:16 PM   #6
earthmate is not NMEA standard
aka Kumaneko
Old 11-25-2002, 05:54 PM   #7
I found this yesterday in relation to something from UK Ebay:
http://www.users.bigpond.com/tobbe/aisin_gps.htm
HTH
Dave
thenominous is offline   Reply With Quote
Old 11-25-2002, 06:41 PM   #8
IIRC the Earthmate has the same protocol as the tripmate, correct? If that is the case then it's very easy to convert it to NMEA standard (as I did)... The only difference is that these GPSs expect to hear "ASTRAL" on the com port before they will start dumping NMEA data... Luckily they are already broadcasting "ASTRAL" out approx once per second. So there is 2 hacks that you can do:
In both hacks you have to open her up and solder in a jumper between the DTR pin (RED wire, pin 4) and the +ve power pin from the battery harness, this will cause the tripmate to go "online" as soon as power is applied to it so that the other hacks can work. It's recommended to remove the red wire connection to the GPS once you do this.
Now you have 2 choices more:
1) Install a jumper between TX (black pin 2) and RX (brown pin 3) so that once the GPS powers on it will start broadcasting "ASTRAL", it will hear that and then switch to online mode and start broadcasting NMEA data. You need to remove the brown wire connection to make this work. Note that now you cannot send data to the GPS to configure anything (this is not normally needed anyway, but since these GPSs have a special "binary" mode (not NMEA compliant) that can give you a lot more information than just NMEA can, you might want to use option 2)
2) Don't do anything else, but before you start any GPS program on your computer, set up a simple script to send "ASTRAL" to the com port. Note that this will only work since the DTR pin has been removed and hardwired to be always-on. So once this is sent it will stay in full online mode broadcasting NMEA data until you power it off. This method requires you to do something special on the computer side before using any software, but it will allow you to retain the ability to talk to your GPS.
I did this to mine by the instructions from this guide and it worked like a charm, works great now with VisualGPS-XP and Streets&Trips 2002.
The #2 option is speculation from me and I haven't tested it yet, however I see no reason why it shouldn't work. Since I have no need to switch it into binary mode or configure which NMEA sentances it will send out I just did the full hack and left it.
It's powered directly from my +5V source on my power supply and works like a charm now. I hacked streets and trips to give me a 1second update interval and now I'm pretty happy. However I'm pretty ticked off at the limited ability for S&T to track and provide the driver with driving instructions. Does anyone know of a better program to use than S&T 2002?
Old 01-10-2003, 05:56 PM   #9
This reply is a little late.. but the earthmate doesn't use NMEA data, it's totally proprietary, there is a small device you can buy to make the conversion.. but it isn't cheap. (though maybe cheaper than buying a new gps though)
aka Kumaneko
