Old 01-04-2008, 07:03 PM   #1
alienmanfc6's Avatar
DeLorme Hacks
For those of you have are using DeLorme Street Atlas 2008 and hate the info bar on the right side and the split map on the left side when you are GPS tracking like I do. I have found a way to get ride of them. I found this out playing around in the windows registry and thought i would post it so other ppl can benifit from my findings. Here are the steps...
1) Click start and select run
2) Type 'regedit'
3) find this key to get ride of the split map on the left
HKEY_LOCAL_MACHINE\SOFTWARE\DeLorme\SA2008\DeLorem Components\DeLorme.SA2008.GPS.1\AppDefaults
4) find the entry called 'AutoSplitMapSuppport'
5) change this value to 0
6) to get rid of the info bar on the right find this key
HKEY_LOCAL_MACHINE\SOFTWARE\DeLorme\SA2008\Screen\ 800x600
note - you need to select whatever screen size you use. mine is 800x600
7) find the key called 'InfoWidth'
8) change this value to 0
And next time you start DeLorme these will be gone. if you want them back the change the values back to what they were. AutoSplitMapSupport will be 1 to turn it back on and the InfoWidth will vary because it is in pixels. Mine was 62 in hex and 98 in decimal. Hope this helps someone.
alienmanfc6 is offline   Reply With Quote
Old 01-23-2008, 11:39 AM   #2
Did this help anybody? just curius cuz no one has replyed
Old 01-24-2008, 01:09 AM   #3
Have not tried this yet,but plan too. Always hated the split screen. Thanks!
kyjoe is offline   Reply With Quote
Old 01-25-2008, 05:24 PM   #4
Can you post a picture of how it looks??
JDMinPDX is offline   Reply With Quote
I replaced the male voice of my Delorme Street Atlas with a british female voice... dmbrown73 GPS 21 03-07-2006 11:43 PM
25 lost hacks P3rv3rt B3ar General MP3Car Discussion 8 10-25-2005 01:34 PM
FS: XM PCR and DeLorme Earthmate RedGTiVR6 Classified Archive 12 05-02-2005 10:14 AM
iGuidance with Delorme USB Receiver muldrick GPS 23 12-12-2004 08:30 PM
Will Delorme USB GPS work with Copilot7? DLe GPS 12 09-06-2004 07:34 PM
