The MP3car.com Store
Thread Tools Display Modes
Old 01-05-2008, 04:30 PM   #1
devin98's CarPC Specs
My Photos: (0)
Xport
Hi,
I am using Xport trying to get my GPS receiver not to loose lock and have to be disconnected after hibernation however it still needs to be disconnected and connected again or I need to wait 5-10mins for it to come back.
Any ideas I have tried everything!!
devin98 is offline   Reply With Quote
Sponsored Links
Old 01-05-2008, 07:19 PM   #2
Curiosity's CarPC Specs
Curiosity's Avatar
Vehicle: 98 Trans Am
My Photos: (3)
Does the data stop or is it just taking that long to get a fix once it returns from hibernation? And what GPS is it?
XPort 1.24 -GPS port splitter, logger, and USB device resume fix
Curiosity is online now   Reply With Quote
Old 01-06-2008, 10:22 AM   #3
My Photos: (0)
It appears the data is still coming in after hibernation but takes a long time to get a fix 5-10mins. I am using the BU-353
-Devin
Old 01-06-2008, 11:45 AM   #4
Dimon(rus)'s CarPC Specs
Vehicle: Astra F, H
My Photos: (14)
How old is your BU353? How long it fixes using comport directly, with xport switched off? What percentage of sky is viewable while `it fixes too long`, does the fix faster while the car not moving?
Dimon(rus) is offline   Reply With Quote
Old 01-06-2008, 02:34 PM   #5
Curiosity's Avatar
My Photos: (3)
It's probably the GPS. Some have trouble, and some don't. Mine gets 8-12 sats by the time Windows is loaded. The first thing I would do is load GPSInfo or open the window in a nav program that shows sat count, signals and positions. If satellites are showing only low signal strengths or very few or only on the sides or center then you have something blocking the signal. Stick it outside the window, and move it around as much as you can while watching the display. The BU-353 is very sensitive and can pick up very well but not through metal or tint. Otherwise, if sticking it out the window doesn't get 8+ high signals, then there's probably something wrong with it.
Old 01-06-2008, 07:09 PM   #6
My Photos: (0)
If I run the GPS though Iguidance directly there is no delay is getting locks. I normally have 7-10 sats locked. If I look at Xport the data is flowing no problem.
-Devin
Old 01-06-2008, 09:40 PM   #7
Curiosity's Avatar
My Photos: (3)
I'd say get rid of XPort. Is the virtual port used bewteen iGuidance and XPort COM9 or lower? I know it has trouble with 2 digit numbers. Can't think of anything else really.
Old 01-07-2008, 10:05 PM   #8
My Photos: (0)
Well I read that also I have the ports set for under COM9
Old 01-08-2008, 11:31 PM   #9
Curiosity's Avatar
My Photos: (3)
Give this one a try and tell me if it works any better. Thanks.
http://curioustech.home.insightbb.com/XPort3test.zip
Sponsored Links
vB code is On
Trackbacks are Off
auto start xport to be preconfigured andyman GPS 4 12-20-2007 09:28 PM
XPort Question kozmo Software & Software Development 1 04-10-2007 08:37 AM
XPort proble Rootus Software & Software Development 4 04-13-2006 02:01 PM
Xport 3 problems Cheekz185 GPS 17 02-27-2006 10:15 PM
Some warnings about Deluo Routis 2004, MapPoint 2004 & XPort dumpper GPS 13 07-15-2004 12:07 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
