The MP3car.com Store
Thread Tools Display Modes
Old 01-08-2008, 07:54 AM   #1
My Photos: (0)
can i instal nav software on pc/laptop
hello!
I was wondering if i can get the navigation software from my PDA work on my pc/laptop?
and can i used the mio gps antenna to work on my laptop as a gps receiver?
thanks!
mosheva is offline   Reply With Quote
Sponsored Links
Old 01-08-2008, 08:26 AM   #2
GuMiSZu's Avatar
Vehicle: 94/Toyota/Corolla 1.6GLI
My Photos: (0)
yes you should pocket pc controller to get the PDA screen to pc it works > i tried it.
but maybe you can use IGO on XP
just look at an another topic
Englishlessness :(
GuMiSZu is offline   Reply With Quote
Old 01-08-2008, 08:39 AM   #3
My Photos: (0)
i dont want to see the pda screen on my pc i want a software that i can use only the GPS antenna that will work like a blueTooth gps antenna...
Old 01-08-2008, 09:06 AM   #4
GuMiSZu's Avatar
My Photos: (0)
ohhh
use the gpsgate . It can make it.
You must install this prog to PDA and XP too, and set up in PDA BLUETOOTH SERVER.
if it's done you can find it with carpc via gpsgate
Englishlessness :(
Old 01-08-2008, 09:09 AM   #5
My Photos: (0)
3d gps
Make sure you get 3d software from tele atlas
http://images.google.com/imgres?imgu...n%3D0%26sa%3DN
dmart23 is offline   Reply With Quote
Old 01-08-2008, 09:40 AM   #6
My Photos: (0)
http://gpsgate.com/index.php?id=14
direct link to the GpsGate Client for Pocket PC.
If you're using a internal GPS in your PDA then I think you can just set your GPS as input in GpsGate then send it as a BT output to your PC. Don't think you need GpsGate Client for Windows. might be wrong. I'll try it out.
GPS tracking
mcuz is offline   Reply With Quote
Old 01-08-2008, 10:51 AM   #7
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
I think we're missing the boat here.
No, GPS software for your PDA will not work on your laptop. You need Windoze software on the laptop (assuming you run Windoze).
It's also likely that the GPS receiver iwll not work on the laptop and you'd need a USB or serial unit made for PC use.
You may be able to use teh PDA w/ GPS as a GPS receiver on the PC. I've never set this up, so I can't help with that.
GPS receivers are cheap (US$50 or so), though.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 01-08-2008, 02:49 PM   #8
GuMiSZu's Avatar
My Photos: (0)
"You may be able to use teh PDA w/ GPS as a GPS receiver on the PC" > o wrote the method that can he use. GPSGATE the solution...
Englishlessness :(
Old 01-08-2008, 03:02 PM   #9
My Photos: (0)
success!
there is a software which and her name is GPS2BLUE
it open a virtual com port on the pc/laptop and this is how it only connected to the GPS antenna
on my MIO PDA so the pc/laptop think it connected to a GPS antenna via USB
I running on my pc destinator 7 and so far so good...
so thanks anyway...
(sorry for my English)
Sponsored Links
vB code is On
Trackbacks are Off
Elmscan 5 w/bluetooth wireless obd scanner reviews speedy007 The Review Palace 3 06-02-2008 05:59 PM
Damn I wish I had this POI in my Nav Software lostreception GPS 5 04-26-2007 12:45 PM
Any nav software updates over internet? pip GPS 4 11-05-2005 11:50 PM
Best nav software for use in the UK? l9nux GPS 6 09-10-2004 09:27 AM
??? 3d GPS nav software for the US ??? AVmobile Software & Software Development 6 01-06-2004 11:32 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
