The MP3car.com Store
Thread Tools Display Modes
Old 04-19-2008, 09:41 PM   #46
bes51659's CarPC Specs
bes51659's Avatar
Vehicle: 01/BMW/325ti
My Photos: (6)
Thanks guys! I will probably be able to sell this piece of kit eventually. Depends on interest.
Today I got my first NMEA log! Wonderful feeling... (below)
It will take a bit longer to try out the gyro circuitry. I also want to write the code for interpreting BMW IBus speed messages and simulate tacho pulses before I am done with this design. So with an E46 you will not have to connect tacho and direction signals. You can do if you've got another car.
Plan is to be done in June.
Highslide JS
BMW OEM GPS Antenna (part numbers are visible)
Highslide JS
GPS in box.
Edit:
I've now got valid GPS data so I know that my antenna is working!¨
$GPVTG,000.0,T,,M,000.0,N,000.0,K,A*0D
$GPRMC,132321.93,A,5921.39125,N,01758.66222,E,000. 0,000.0,230408,,,A*53
$GPGSA,A,3,27,08,04,07,02,25,,,,,,,5.05,3.47,3.68* 04
$GPGSV,3,1,12,27,40,188,39,10,14,300,,13,85,142,,0 2,40,277,32*78
$GPGSV,3,2,12,20,11,133,,29,12,348,,23,,000,,08,10 ,198,34*70
$GPGSV,3,3,12,16,25,060,,04,37,230,41,25,61,154,32 ,07,43,178,40*73
$GPGGA,132322.93,5921.39122,N,01758.66224,E,1,06,3 .47,00024.4,M,023.4,M,,*6F
Btw. Is someone using time data to set time in car?
Last edited by bes51659 : 04-23-2008 at 01:32 PM. Reason: Now with accurate GPS position
bes51659 is offline   Reply With Quote
Sponsored Links
Old 04-23-2008, 03:07 PM   #47
bes51659's Avatar
My Photos: (6)
Ha ha! http://www.mp3car.com/vbulletin/road...car-clock.html
Old 04-23-2008, 04:15 PM   #48
My Photos: (0)
Look's sweet, will be interestet... But what do you think the price will be? And what kind of technology is the GPS using, how many channels and so?
-Stomp- is offline   Reply With Quote
Old 04-24-2008, 02:46 AM   #49
bes51659's Avatar
My Photos: (6)
It is sweet isn't it :-)
It is the top of the line module from trimble. I think that is its edge, lots of satellites and dead reckoning. And you can use the OEM GPS antenna.
And it will contain power functionality. That is it will power on PC and LCD with configurable timing as well as rearview camera, remote input on poweramp, etc. On a BMW with IBus you will get extra nice features.
My two prototypes was 358€ (each!), but I will be able to shave some of off that. Box alone was 70€ which is what you normally pay for the entire gps receiver :-)
When I've verified design and completed code I will put it into "General Hardware - User innovations" forum with youtube links.
Old 04-26-2008, 02:35 PM   #50
bes51659's Avatar
My Photos: (6)
Highslide JS
Proto 1 fully assembled and I think I've found all design errors. Next week I will make my first tour with it in my car. Writing code for the 8051 at the moment!
Sponsored Links
Old 04-28-2008, 07:57 PM   #51
My Photos: (0)
Cool
Quote: Originally Posted by bes51659 View Post
Highslide JS
Guys I have been trying to do this for a long time and have been watching over the details here for some time.
Just an update the Lassen DR+GPS thing is now available in Ebay for $35 from seller "oh2gma".
check this out, you can get this cheap. If you are looking out for this thing to complete and work you can try your luck to get the board now cheap.
http://cm.ebay.com/cm/ck/1065-29392-...m=320241899819
cheers
amitchatbd is offline   Reply With Quote
Old 04-30-2008, 09:05 AM   #52
bes51659's Avatar
My Photos: (6)
Very good price indeed!! I think I paid £50 for my unit. (And 60$ for the gyro that you still need)
I have 8 pcb's that are left overs from the two prototypes that I've built. I will build them into GPS units without the cpu and without the case and _maybe_ without GPS and gyro. With all interface electronics (regulators, op's and some passive components). I should be able to make 8 "down to the bone" units like that for $100 + p&p. (pcb was a little over $50. Gyro op-amp was $18)
PM me if you are interested in such a kit.
Old 05-02-2008, 02:23 PM   #53
bes51659's Avatar
My Photos: (6)
It works!
It was quite fun at first to see the Kalman filters slowly adjust to tacho and gyro ratio. It overreacted and put me straight into buildings :-)
I did not loose GPS position once, even if I was off position sometimes. Aspecially at beginning in thunnels before calibration was done.
I will make U-tube tomorrow.
With antenna on roof, and with pcb in alu-box I think it will work even better!
Highslide JS
Connected to IBus and power only, speed and direction is decoded from communication and has not got to be wired separately.
The second little pcb is an IBus Resler interface. I wanted to log IBus traffic with the laptop too.
Highslide JS
OEM antenna
Highslide JS
Highslide JS
Edit:
Cannot find the #*% firewire cable do download the video... I will buy one on monday.
Old 05-02-2008, 03:20 PM   #54
My Photos: (0)
Amazing :-p That's great... Look forward to se the youtube video :-)
Old 05-06-2008, 04:27 PM   #55
bes51659's Avatar
My Photos: (6)
Finally a YouTube Demo Video
First time I've made a Video and published it on youtube. Next time I will use a script, a voice reading from script, and a camera man. And maybe a driver :-)
GPS DR Demo
http://www.youtube.com/v/7CWpugLGUjU
Highslide JS
This is it, fully assembled.
Extra connector for inputs when used in non-BMW car witout IBus.
Mount angles can be put inwards instead of outwards
Sponsored Links
vB code is On
Trackbacks are Off
OnStar antenna as external GPS antenna? W1N GPS 25 07-10-2007 08:27 AM
Holux GM-213 USB GPS Receiver, Good? girbot GPS 2 04-23-2006 11:35 PM
Hacking a Holux GM-210 for external antenna (doesn't work) mpquattro GPS 9 04-22-2006 08:22 AM
Help with External GPS on RR Pabs Road Runner 4 06-17-2005 11:22 PM
Does the rikaline bluetooth gps have an external antenna connector? big_cali_dave GPS 3 01-20-2005 01:58 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
