The MP3car.com Store
Thread Tools Display Modes
Old 01-27-2008, 03:50 PM   #1
Vehicle: 2006 Jeep Rubicon Unlimited
My Photos: (0)
GPS Antenna Mounting in a Jeep
Greetings, all. I'm new to all of this and am about to embark on my jeeputer project. I've noticed a few TJ owners posting in this forum and have a question for you...
What GPS antenna did you use, and where did you mount it? It appears as if the USGlobalSat BU-353 is fairly popular but my initial impression is that it is too wide to fit in the roll bar padding.... because IMHO putting a GPS antenna inside the padding of the roll bar is by far the best location as it would be on the top of the vehicle and I can neatly run the wires out of sight back to the 'puter.
Thoughts?
Anyone know of a slimer GPS antenna on the market? (doesn't have to be waterproof as it will remain inside the vehicle)
BlackRuby is offline   Reply With Quote
Sponsored Links
Old 01-27-2008, 04:13 PM   #2
FusionFanatic's CarPC Specs
FusionFanatic's Avatar
Vehicle: '07 Ford Fusion
My Photos: (56)
I used to own a TJ and I had my XM sat radio antenna on the roll bar, under the padding. it fit in there fine and it worked great.
I don't have my jeep anymore, but I DO use a Globalsat BU-353 antenna and I can tell you it's almost the exact same size as my XM antenna. I can't imagine any problem at all fitting it under the padding. if it really was a tight fit then you could always cut out some padding (you won't see it because it will still have the nylon cover over it)
I know first hand that the BU-353 works great so I can highly recommend it
good luck with your carPC
FusionFanatic is offline   Reply With Quote
Old 01-28-2008, 11:06 PM   #3
My Photos: (0)
Thanks for the quick reply -- I think I'll give it a shot and let everyone know if it fits. It'll be perfect if it does...
Old 02-16-2008, 09:49 AM   #4
FTWRUBI's Avatar
Vehicle: 03 Jeep Rubicon
My Photos: (3)
You can notch the foam around the roll bar and it will fit great. I installed a tuffy overhead console and that is where all of my puter stuff is going except the screen. I will post some pix when I get done.
FTWRUBI is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
OnStar antenna as external GPS antenna? W1N GPS 26 08-14-2008 07:49 PM
Attention Newbies! Everything (almost) you want to know about GPS (Part 1) Bugbyte GPS 55 06-08-2008 08:54 PM
Anyone recommend a good USB GPS with external antenna output? ccrobin Centrafuse 10 10-08-2007 03:21 AM
Solder cable of external antenna inside mouse GPS ?? swissRv GPS 11 12-06-2004 03:48 PM
Gps Module + External Antenna + Waas + Usb e_z_street GPS 3 10-06-2004 03:57 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
