The MP3car.com Store
Thread Tools Display Modes
Old 02-03-2008, 08:38 PM   #1
My Photos: (0)
Iguidance 4 install location
It seems that iguidance is hardcoded to look for maps/any other stuff from c:\program files/....., is there any way to tell iguidance to look for program files from a different location? Like d:\iguidance, or something? This is pretty poor programming on iguidance's part if they hardcode such a thing....i may have to look for an alternative solution if i cant change the location.
[H]Bugster is offline   Reply With Quote
Sponsored Links
Old 02-04-2008, 12:04 AM   #2
My Photos: (0)
i'm not sure if this is wat you want, but installed iguidance then place a copy of the image file on another drive, and mount that drive with a virtual iso program, and that worked perfectly. Hope that helps you out. If you want a free program its called magicdisk or magicdisc.
Punky is offline   Reply With Quote
Old 02-04-2008, 09:51 AM   #3
My Photos: (0)
copy the installation files to the root of any local hard drive (C: for example), run setup.exe from the hardisk instead of the CD.
IGuidance will then load the maps from the hard drive it was installed from.
Stav
stavrosg is offline   Reply With Quote
Old 02-04-2008, 04:39 PM   #4
pnyboy27's CarPC Specs
Vehicle: 1992 Lexus SC300
My Photos: (0)
so since i have mine installed, i have to uninstall it and reinstall it again but without the cd? what about the license key? that will be reusable?
pnyboy27 is offline   Reply With Quote
Old 02-04-2008, 06:22 PM   #5
tn6478's Avatar
My Photos: (0)
i have my maps on d:\inav\iguidance and my install in C:\program files\inav\iguidance. It pick up my maps without me even routing it. This is how i have been installing my iguidance 4
tn6478 is offline   Reply With Quote
Old 02-04-2008, 06:23 PM   #6
tn6478's Avatar
My Photos: (0)
you can just move the map files to d:\ or any other location
Old 02-04-2008, 11:25 PM   #7
My Photos: (0)
Moving it doesnt work. I've even tried with copying the install CD to the location where i want to install, then reinstalled. When i load up, it says Cannot find map data files.
I moved the install files to d:\apps\iNav Guidance\Setup
The maps are in d:\apps\iNav Guidance\Setup\Maps\
I installed to d:\apps\iNav Guidance
Old 02-05-2008, 07:25 AM   #8
My Photos: (0)
Important part.. The root directory.
Copy the setup files to D:\
So you have;
D:\setup
D:\iNav iGuidance
D:\setup.exe
etc..
Then re-install
Old 02-05-2008, 10:01 AM   #9
FusionFanatic's CarPC Specs
FusionFanatic's Avatar
Vehicle: '07 Ford Fusion
My Photos: (56)
the manual only gives instructions for the C: drive, but I think it will work on other drives as well but it has to be in the drive root. in other words you cannot have it in your "apps" folder, it would need to be in D:\iNav iGuidance\
just move it into the root and it should work fine
FusionFanatic is offline   Reply With Quote
Old 02-05-2008, 11:40 AM   #10
My Photos: (0)
Thanks guys, root folder works!
Sponsored Links
Old 04-27-2008, 07:24 PM   #11
My Photos: (0)
Ok.. Im a total newb at this can some one explain this to me as if I had no idea what you were talking about and I was slighty brain dead.. Thanks
psigti is offline   Reply With Quote
Old 04-28-2008, 06:25 PM   #12
tn6478's Avatar
My Photos: (0)
copy the map to the root of your D:\
"Example: D:\Inav
IG4 will pick up your maps
Old 05-01-2008, 09:15 AM   #13
My Photos: (0)
thats that part I dont understand.. I cant find anything that says maps... nor do i know what the root is.. but thanks for the reply.
Old 05-01-2008, 01:15 PM   #14
tn6478's Avatar
My Photos: (0)
if you dont understand putting your maps files in D:\iNav iGuidance\. I dont know what else to say man. Get Technical help
Old 05-26-2008, 06:18 AM   #15
My Photos: (0)
is the map file called anything other than maps.. cause that folder is empty
Sponsored Links
vB code is On
Trackbacks are Off
Automatic Weather Update/GPS Location Labels.. How they work and problem solving. Sonicxtacy02 RR FAQ 2 10-10-2007 08:24 AM
iGuidance 3.0 with Onstar Hack won't stay connected Uraijit GPS 1 09-21-2007 08:24 PM
any way to install Iguidance without dvd drive? Snortonnorton GPS 8 07-16-2007 12:12 PM
Can't get Flash Player to install boat Newbie 3 12-10-2006 01:49 PM
Iguidance Install Problem tbird2340 GPS 13 01-08-2005 09:44 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
