Quote: Originally Posted by
Dougw133
OK... I used SiRF Demo (google it, free download) and really had no idea what I was doing. It still debuged as usual nad gave logs. However, after scrapping about for about and our, like magic I locked onto 17 Sats.. ?? I wish I could tell you exactly what was wrong in hopes of helping others, but I have no clue!
Thank you anyways...
The only other thing i can suggest is checking the following
1. in device manager goto advanced properties on the com port its been allocated and check its baud rate it shud be 4800, the rest should be default values.
2. Check that the same settings are apllied to your GPS program using the same com and baud rate.
3. You are using a compatible setting ie SIRF/NMEA
These units should be usually a plug and play have you tried it with any navigation software?
