I use Iguidance 4 in the car, but I prefer S&t for route planning.
I've used 2008, seems fine, pretty much like the previous versions with a few new features and updated maps.
The GPS puck should work fine with export as all xport does is split the port into a couple virtual ports. Remember, I said should............
I don't think any of the current skins or FE support S&T by default due to the interface issues mentioned above. You can embed it and it will work fine, I have before but switched to IG 4 for the 3d view.
Leonardo Da Vinci
