Old 02-24-2008, 02:45 PM   #1
LFPerf is an unknown quantity at this point
Xport Issues
Ive used Xport in the past with great results, due to a laptop bios failure I had to start all over with a different machine. I went to set up xport yesterday for use with iguidance and roadrunner. After a few minutes of running (working fine) either a error comes up saying an error has occurd and xport needs to shut down, or xport just shuts down with no warning. I've removed and reset it up a few times with the same outcome, any ideas?
LFPerf is offline   Reply With Quote
Old 02-24-2008, 03:00 PM   #2
What can I say? I like serial.
Curiosity's Avatar
Curiosity will become famous soon enough
Wow. I wonder how many people got that last one? Download the new version. Sorry.
XPort 1.41 -GPS port splitter, logger, and USB device resume fix
GPS DirectShow Filter / XOBD / MiniCam
Curiosity is offline   Reply With Quote
Old 02-24-2008, 03:36 PM   #3
wow, speedy service. i'll try it out
Old 02-28-2008, 05:42 AM   #4
Spacelord is an unknown quantity at this point
Hi Curiosity,
I have used XPort for already a year to split GPS-Port, what was working fine.
Now I bought a GPS/TMC-Mouse (Navilock 409TE) and I'm trying to get TMC-Signal into the navigation software. This doesn't really work. I managed to get TMC connected with the XPort verision 1.19, but GPS-Signal was very unstable, appearing and disappearing every 20 Seconds or so and apparently a BSOD. With the 1.20 I get GPS connected, but TMC on the other port cannot be initialized. Do I do something wrong or is XPort not designed to handle TMC-Data?
Car: Ford S-Max 2,5T
CarPc: intel D201GLY, 7"-Touchscreen, RoadRunner, IGo8
HiFi: Alpine CDA 9855R, Diabolo D19/AA165g, Tymphany LAT500, Signat RAMbo, AudioSystem f2-300
Spacelord is offline   Reply With Quote
Old 02-28-2008, 11:13 AM   #5
Curiosity's Avatar
I've never seen TMC data so I can't really give you an answer.
Old 02-28-2008, 02:04 PM   #6
would it help to send you the actual GPS log?
Old 02-28-2008, 02:22 PM   #7
Curiosity's Avatar
Yes, I think that may help. Also, what do you mean by the "other" port? Is there more than one COM port and how do you initialize it?
Old 02-28-2008, 02:27 PM   #8
I'll grab it tonight and attach. *done*
afaik TMC data is sprinkled among NMEA strings separated by "?"
The SW I use (iGO8) needs GPS and TMC on separate ports, so I split the original signal with XPort and feed iGO with the virtual ports
Old 02-28-2008, 06:37 PM   #9
Curiosity's Avatar
That can't be good. There is mixed text and binary in it. I see 3F D5 .... 3F inserted in the middle of NMEA sentences which should be causing problems with your software. It won't be able to find the TMC data in all that mess. It's kind of like 2 things are sending messages that don't know about each other. Try to find some kind of option that is designed to allow them both to work together if there is one. There could also be a baud rate setting for the TMC or second output that is different, but I really think it's made to output on seperate ports.
Old 02-29-2008, 05:14 AM   #10
the funny thing is, it does. If I set a splitted port as TMC port in iGo and do not configure GPS properly, iGO receives TMC correctly.
ShowGPS receives NMEA and TMC on one port so the data seems to be correct.
Does XPort somehow parse/analyze received data or is it forwarded raw to the virtual ports?
Old 02-29-2008, 07:09 AM   #11
Curiosity's Avatar
XPort does nothing with it. Your logs should look the same with or without XPort. The problem is that iGo can't deal with the NMEA broken up by the TMC data. Try ShowGPS through XPort. It should work just fine.
Old 02-29-2008, 07:28 AM   #12
I'll test it. thanks
Old 02-29-2008, 02:19 PM   #13
Jesus Freak
antimatter's Avatar
antimatter is on a distinguished road
I had the same problem. Ill trry the new one at lunch today
antimatter is offline   Reply With Quote
Old 03-06-2008, 06:15 PM   #14
I've got it working with GPSGate, setting a NMEA filter. You were right, iGo doesn't understand broken NMEA data.
Old 03-07-2008, 08:34 PM   #15
Curiosity's Avatar
I don't think any nav program can handle that, and that's why I think it's probably a wrong setting. But then if you can get it to work, that's good. I think I would have tried to work with a standard, like insert a $GPTMC,x,x,x,x*XX sentence in there so it would just automatically be ignored by anything that doesn't understand it. That would make things too simple though.
xport + AyAy Sir crash problem. Punky GPS 14 07-24-2008 02:30 AM
Trying to fix timing issues with M2 matt11601 Power Supplies 0 06-06-2007 10:51 PM
Touchscreen Issues w/Hibernation & CNX-P1290 jmciver Power Supplies 0 12-20-2006 08:48 PM
Verizon Novatel 620 issues MobiTekLink Wireless Communications 30 12-02-2005 04:35 PM
Power issues in 03 Mustang tj!2k4 Power Supplies 17 12-22-2004 02:16 PM
