Old 02-24-2008, 05:17 PM   #1
HzzyMx3 is an unknown quantity at this point
Gps disconnects :( help please
Hello all. .
I just finished building in my carPC 2 weeks ago and now i started fidling around with the rest of the functions i can use it for . . BUT . . As soon as i start Mapmonkey everything is fine. . I can use it for hours and hours without a singel problem. . But as soon as i start using my gps device, in this case COM4 in RR itself *(without running any other app using that port ofc)* It works fine for about 10 mins and than my com just crashes. Its not only on my carpc but also on my laptop wich i use for testing it all .
At first it made my entire RR crash but i fixed that by removing the zip**.dll now i can just keep on using RR but to be able to RE-use my gps device i have to either reboot my entire pc or turn it on and off.
I wonder if any of you know a solution for this or atleast where to search it, in windows itself or in RR. . I've been searching for a solution for the past 2 days and i'm completely lost . . . .
*(i also tried reinstalling it on another com and multiple settings for blue-tooth ofc.)*
Thanks in advance .
Hzzy-MX3
1.8 V6 136 standard.
HzzyMx3 is offline   Reply With Quote
Old 02-24-2008, 05:44 PM   #2
v8 scimitar's Avatar
v8 scimitar is on a distinguished road
Am I reading this right, you are trying to use your GPS with two applications on the same port? If that's the case you cant do that you need to split the ports with a port splitter like xport or similar. A GPS port can only be used by one application at a time. If you don't want to use a port splitter the take a look at freedrive instead as RR will talk directly with that and get all the GPS info it needs.
Visit my site V8 Scimitar
SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
v8 scimitar is offline   Reply With Quote
Old 02-25-2008, 04:35 AM   #3
Tnx for the reply
But nop i'm not using the gps with 2 programs . . Only with RR atm . . As soon as i wanna navigate i just close RR and start up mapmonkey <-- Still got the embedding problem with mapmonkey in roadrunner
I just gave mapmonkey as example couse that keeps working for hours @ a time without a singel crash from my gps .
And as soon as i start gps in RR it just crashes. This is for example if i start GPS stats, it works fine for a couple of mins and than my gps hangs and the com port disapears from the system. .
Tnx
Old 02-25-2008, 11:31 AM   #4
What can I say? I like serial.
Curiosity's Avatar
Curiosity will become famous soon enough
Get a BU-353.
XPort 1.41 -GPS port splitter, logger, and USB device resume fix
GPS DirectShow Filter / XOBD / MiniCam
Curiosity is offline   Reply With Quote
How to setup iGuidance GPS for RoadRunner MatrixPC RR FAQ 31 05-22-2009 09:29 AM
PPC Car GPS and MP3 mini How To hotrod_nut General Hardware Discussion 1 02-25-2008 02:24 PM
MS Streets & Trips 2007 w/ GPS Locator EQNish GPS 3 08-10-2007 05:03 PM
few gps questions fuctup GPS 2 03-02-2005 02:40 AM
