Old 02-29-2008, 08:49 AM   #1
MastaKebob is an unknown quantity at this point
XPort/BU-353 hibernation
I remember seeing a post a while back on freezing problems with the BU-353 and xport when coming out of hibernation, but I can't seem to find them again so I'm making a new post.
I have a BU-353 (USB GPS) being routed into XPort so that both RoadRunner and iGuidance 4 can access it. However, sometimes (about 50% of the time), when my carpc comes out of hibernation, neither RR or iGuidance are receiving GPS info. When this happens, xport's little information block down at the bottom of the window shows it frozen on some random GPS string. The only way to unfreeze it is to unplug and replug the GPS receiver. Anyone have this problem/know how to fix it? Is it a hardware issue (BU-353 not getting restarted on hibernation resume) or a software issue (xport not liking hibernation)? Thanks in advance for any help.
MastaKebob is offline   Reply With Quote
Old 02-29-2008, 12:37 PM   #2
What can I say? I like serial.
Curiosity's Avatar
Curiosity will become famous soon enough
Have you tried checking the device in the device list on the bottom? Is it on a hub with other USB devices?
XPort 1.41 -GPS port splitter, logger, and USB device resume fix
GPS DirectShow Filter / XOBD / MiniCam
Curiosity is offline   Reply With Quote
Old 03-06-2008, 07:08 AM   #3
"checking the device in the device list on the bottom"... Not really sure what that means. Device list on the bottom of XPort? Cause there's no device list on the bottom of xport, just a display of the current NMEA data. Is there supposed to be a device list? Do you mean the virtual port selections? Yes, they're both set to the correct ports (5 and 6 if you're curious) with input port == 3. And I have the "enable service" box checked. Not sure if this will change anything, but I've started leaving the XPort program 'open' (not minimized to the taskbar) all the time. I hope this will help, but I haven't been able to really test it thoroughly yet.
The GPS is plugged into the computer directly, no external hub. But, correct me if I'm wrong, and I'm kinda going on a tangent here, I was under the impression that all USB ports on a computer were all attached to the same central internal/logical USB hub, so what difference would attaching another hub make anyway? I thought that was the whole point of USB, that it was daisy chain-able.
Old 03-07-2008, 02:12 AM   #4
Nomader's Avatar
Nomader is on a distinguished road
download the latest xport, and you will see the list..
you can always try and download gpsgate, which does the same job and is a little more stable..but it is not free..download the trial and see..
Nomader is online now   Reply With Quote
Is Hibernation button the same as hibernation event? TheBiz StreetDeck 1 11-28-2006 10:32 AM
Hibernation drawing too much power... Borte General Hardware Discussion 21 09-06-2006 09:03 AM
Audigy 2 NX and hibernation backspace Car Audio 2 04-28-2006 02:56 PM
5 minutes to complete hibernation? WTF? DRWeside General Hardware Discussion 1 03-12-2006 11:36 PM
Odd Off Topic-ness on Hibernation Vchat20 General MP3Car Discussion 1 01-31-2005 06:41 PM
