Old 03-12-2008, 09:49 PM   #1
deeznudts's Avatar
GPS is way off
I thought this was a street deck problem at first. But now I think it's a problem with my GPS receiver. When I fire up my SD navigation 7 times out of 10 it says I'm in Las Vegas. Which is weird cause I live in NJ. I'm using the pharos GPS usb receiver which comes with streets and trips. The usb connections are all fine, all the com ports are set correctly, and it has a clear view to the sky because it's mounted right under my sunroof. Sometimes the thing works great. In fact it worked great for about 2 weeks. But now most of the time it doesn't. Has anyone ever had this happen to them? Maybe the thing is just busted, but if it's something simple I'd like not to shell out more $$. Thanks in advance for any response.
My 2007 Scion Tc Install
deeznudts is offline   Reply With Quote
Old 03-18-2008, 10:49 PM   #2
I have the same problem and I canot figure it out, I am starting to think that is my receiver.
zodiaco is offline   Reply With Quote
Old 03-19-2008, 07:21 AM   #3
deeznudts's Avatar
What front end are you using? I'm running streetdeck 1.1.1.6. I found out the problem in mine. When I adjusted the driving speeds in SD it throws it way off. But when I reset them to the default it works just fine. Don't ask me why?????
Old 03-19-2008, 03:06 PM   #4
Machinehead's Avatar
What about trying another GPS program outside of SD?
Or even a diagnostic program like SIRFDemo?
Machinehead is offline   Reply With Quote
Old 03-27-2008, 05:00 PM   #5
just get a tomtom go 720...it will solve your problem
dmart23 is offline   Reply With Quote
How to setup iGuidance GPS for RoadRunner MatrixPC RR FAQ 27 07-08-2008 11:34 PM
PPC Car GPS and MP3 mini How To hotrod_nut General Hardware Discussion 1 02-25-2008 02:24 PM
MS Streets & Trips 2007 w/ GPS Locator EQNish GPS 3 08-10-2007 05:03 PM
few gps questions fuctup GPS 2 03-02-2005 02:40 AM
