03-21-2008, 06:56 AM
#1
where do you put your gps reciever?
I have my whole truckputer in my front cab. I don't know where the best place is to place my gps so it stays hidden, yet visible to the sky and stays secured
03-21-2008, 08:08 AM
#2
Neither darque nor pervert
Mine is buried in my dash, under one layer of plastic panel. Works great!
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
03-21-2008, 08:42 AM
#3
Rear package shelf under the "carpet".
Works great never have a problem with reception.
Cheers
Leonardo Da Vinci
03-21-2008, 09:35 AM
#4
so maybe I can stuff mine in my defrost vent. unless any of you see a problem with the 88 or so degrees of heat affecting that lil unit.
03-21-2008, 09:41 AM
#5
in the sunroof.
good alround reception, be sure to get one that can see through heat-resisting glass
03-21-2008, 09:57 AM
#6
^^ Oh boy, here we go again.........................
Leonardo Da Vinci
03-21-2008, 10:14 AM
#7
+1
03-21-2008, 12:21 PM
#8
haha, looks like i started a thought to have ended subject :P. my bad everyone, my bad.
03-22-2008, 12:13 AM
#9
+1
Been that way for many years, its behind the instrument cluster, only one sheet of plastic dash then windshield. High number of sats constantly.
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
03-22-2008, 10:17 AM
#10
Stuffed mine inside a stuffed ducky to conceal it for security reasons. Then drilled a hole in the duck to mount a suction cup and stuck that on my rear window.
03-22-2008, 07:50 PM
#11
Has trouble reading.
in the small compartment at the rear between the brake light and window (where there is no window tint)...WORKS PERFECT HERE, connects instantly.
When I had the receiver (Globalsat BU-353, previously had a Rikaline 6010) placed on the rear deck next to the 6x9s the window tint degraded the satellite signal a lot, sometimes it wouldnt even connect, or only connect if i restarted the carpc...since i have moved it behind the brake light, it connects very quickly with usually 8-11 satellites.
03-22-2008, 08:00 PM
#12
That's a pretty nifty idea!
If you have a light on the rear deck that is.......
Leonardo Da Vinci
03-22-2008, 09:35 PM
#13
that is nifty. but a truck like mine is a bit harder. if i could only connect it in the rear, then i would hafta look into how GM installed the onstar gps receiver. but since all my setup is up front in the dash, i need to find a good safe place to hide it. i like that stuffing it in a lil ducky. but i cant really do that. and it needs to look natural and flow with my interior and truck personality.
its like getting a hidden spycam for security reasons, and hiding it in a plant in an apartment that is obviously not fit for a plant. ya know?
03-24-2008, 06:48 AM
#14
I put mine on the dash in the front left corner to get it closer to the center of the road for the best reception.
VIA EPIA V 1.1ghz
512mb memory
40gig 3.5" HDD
Slim Line DVD/CDRW
80w DC-DC Monex psu (fried 2, working on #3)
8" Datalux TS LCD
Sound Blaster USB
03-24-2008, 08:02 AM
#15
Sure, any fule kno that the satellite reception is best in the center of the road and worst on the shoulders
| Thread Tools |
| Display Modes |
Linear Mode
