The MP3car.com Store
Thread Tools Display Modes
Old 03-27-2008, 10:48 AM   #1
TeamRSX's CarPC Specs
TeamRSX's Avatar
Vehicle: 2005 Acura RSX-S
My Photos: (11)
Question XPort and BU-353 Problem
I am just trying to set up my Bu-353 gps receiver and Iguidance 4 with Xport.
I had it working the other day on another hard drive and was able to get a fixed location and everything worked, but now i cant seem to get to working.
As of right now i am getting a solid light on the gps receiver which means its on but looking for signal.
I can't seem it to find a fixed signal.
I have installed the drivers that came with the gps receiver and before i used Xport i went into device manager to see what comm port the gps is going to use. Its comm 3 in device manager.
So, then i installed xport and put the input at comm3 and output as comm4.
WHen i open GPSInfo, it sees the gps on comm4 and outputs information, but the light on the receiver still doesn't blink and can't get fixed location.
I have also made sure the baud rate is set to 4800 in xport, device manager for com3 and in GPSInfo
Here is the output from GPSInfo.exe:
01,,29,48,298,*74
$GPGSV,3,2,12,26,20,173,,15,16,181,,30,14,252,,13, 10,032,*72
$GPGSV,3,3,12,05,08,235,,12,07,221,,27,07,067,,25, 06,044,*74
$GPRMC,154408.056,V,,,,,,,270308,,*2E
$GPGGA,154409.065,,,,,0,00,,,M,0.0,M,,0000*58
$GPGSA,A,1,,,,,,,,,,,,,,,*1E
$GPRMC,154409.065,V,,,,,,,270308,,*2F
$GPGGA,154410.056,,,,,0,00,,,M,0.0,M,,0000*50
$GPRMC,154410.056,V,,,,,,,270308,,*27
$GPGGA,154411.056,,,,,0,00,,,M,0.0,M,,0000*51
$GPRMC,154411.056,V,,,,,,,270308,,*26
$GPGGA,154412.064,,,,,0,00,,,M,0.0,M,,0000*53
$GPRMC,154412.064,V,,,,,,,270308,,*24
$GPGGA,154413.055,,,,,0,00,,,M,0.0,M,,0000*50
$GPGSV,3,1,12,02,48,095,,24,41,293,,04,14,101,,29, 48,298,*74
$GPRMC,154413.055,V,,,,,,,270308,,*27
$GPGGA,154414.056,,,,,0,00,,,M,0.0,M,,0000*54
$GPRMC,154414.056,V,,,,,,,270308,,*23
Any help would be appreciated as i seem to be having problems with something. Hopefully its just a setting or something.
TeamRSX is offline   Reply With Quote
Sponsored Links
Old 03-28-2008, 11:04 AM   #2
japeeler's CarPC Specs
japeeler's Avatar
Vehicle: 2006 Ford F150 5.4L XLT 4x4 Screw
My Photos: (0)
Just bought a BU-353 and waiting for it to arrive next week.
I have the BT-339 (Bluetooth) and have connection issues from startup mode, etc.
So trying the USB version. I'll let you know if I figure something out.
If yoy have a COM Port (9-Pin) on your Mobo, then I would try Changing the COM Setting of the GPS, if possible. (I do not know about that GPS receiver, yet) I can on my BT version.
Change the INBOUND COM Port. Put the OUTBOUND COM Port to something like COM8/COM9. This way it is out of the way of your Serial port(s). They use COM3 & COM4 - If you have 2 Serial 9-Pin Ports)
-=- TruckPC Progress -=- 98% Complete -=-
-=- 2006 Ford F-150 Screw 4x4 -=-
@@@@@@@@@@ <-- Planning Phase
@@@@@@@@@@ <-- Purchasing (Never End)
@@@@@@@@@@ <-- Construction Phase
@@@@@@@@@@ <-- Installation Phase
My TruckPC WorkLog @ MP3Car.com
japeeler is offline   Reply With Quote
Old 03-28-2008, 03:25 PM   #3
Nomader's CarPC Specs
Nomader's Avatar
Vehicle: Citroen Xsara 2002
My Photos: (0)
since you are getting a solid light then it means that you do not have a fixed position (no lock) so it is not a software isue at all.. the bu353 does not need software to aquire a fixed position.. it is supposed to get a fix some seconds/minutes after you power it (plug it in to a usb port to get voltage) so most probably you do not have a clear sky above you (the glass in your car maybe??) move the unit in open air and see.
Nomader is offline   Reply With Quote
Old 03-31-2008, 07:24 AM   #4
TeamRSX's Avatar
My Photos: (11)
You are correct.
The first time i tested the gps i was bench testing in my basement and i was able to connect to 2 satellites. When i tried it a few days later it would not get a fixed location.
When i brought it to my friends house to test everything i was able to get a fixed signal.
So, was definately not getting a clear signal from my basement.
Thanks for the help.
Old 03-31-2008, 09:42 AM   #5
Curiosity's CarPC Specs
Curiosity's Avatar
Vehicle: 98 Trans Am
My Photos: (3)
XPort 1.24 -GPS port splitter, logger, and USB device resume fix
Curiosity is online now   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
