XPort and BU-353 Problem
I am just trying to set up my Bu-353 gps receiver and Iguidance 4 with Xport.
I had it working the other day on another hard drive and was able to get a fixed location and everything worked, but now i cant seem to get to working.
As of right now i am getting a solid light on the gps receiver which means its on but looking for signal.
I can't seem it to find a fixed signal.
I have installed the drivers that came with the gps receiver and before i used Xport i went into device manager to see what comm port the gps is going to use. Its comm 3 in device manager.
So, then i installed xport and put the input at comm3 and output as comm4.
WHen i open GPSInfo, it sees the gps on comm4 and outputs information, but the light on the receiver still doesn't blink and can't get fixed location.
I have also made sure the baud rate is set to 4800 in xport, device manager for com3 and in GPSInfo
Here is the output from GPSInfo.exe:
01,,29,48,298,*74
$GPGSV,3,2,12,26,20,173,,15,16,181,,30,14,252,,13, 10,032,*72
$GPGSV,3,3,12,05,08,235,,12,07,221,,27,07,067,,25, 06,044,*74
$GPRMC,154408.056,V,,,,,,,270308,,*2E
$GPGGA,154409.065,,,,,0,00,,,M,0.0,M,,0000*58
$GPGSA,A,1,,,,,,,,,,,,,,,*1E
$GPRMC,154409.065,V,,,,,,,270308,,*2F
$GPGGA,154410.056,,,,,0,00,,,M,0.0,M,,0000*50
$GPRMC,154410.056,V,,,,,,,270308,,*27
$GPGGA,154411.056,,,,,0,00,,,M,0.0,M,,0000*51
$GPRMC,154411.056,V,,,,,,,270308,,*26
$GPGGA,154412.064,,,,,0,00,,,M,0.0,M,,0000*53
$GPRMC,154412.064,V,,,,,,,270308,,*24
$GPGGA,154413.055,,,,,0,00,,,M,0.0,M,,0000*50
$GPGSV,3,1,12,02,48,095,,24,41,293,,04,14,101,,29, 48,298,*74
$GPRMC,154413.055,V,,,,,,,270308,,*27
$GPGGA,154414.056,,,,,0,00,,,M,0.0,M,,0000*54
$GPRMC,154414.056,V,,,,,,,270308,,*23
Any help would be appreciated as i seem to be having problems with something. Hopefully its just a setting or something.
