Old 04-25-2008, 11:37 AM   #31
ptk
ptk is on a distinguished road
Quote: Originally Posted by Marvin Hlavac View Post
4. it will take any garmin map you throw at it. as long as it's in gmapsupp.img format.
Where is this piece of info from? I'm getting some conflicting info, or perhaps I'm just interpreting the info I'm getting incorrectly (which is likely the case).
Are all/most/which-ones Garmin mapping products in gmapsupp.img format?
Coz i just tried it. I removed the US data that came with the disc and put in third party map (malsingmaps.com, it's for Singapore and Malaysia) and viola, what you see on the screen is my street in Singapore.
Now, there is a disclaimer here. At the moment i am not sure if Garmin Mobile PC will read a SD card drive, so I am not sure you can just pop in one of the NT map on SD card and expect it to work. (some one with that kind of setup please try)
However, as long as you can generate the gmapsupp.img from any source (most of us will use mapsource), Mobile PC will take it.
CarPC Ver 4 completed. Aopen i45GMT-HD, C2D mobile 2GHz. Photofast 64GB SSD. Novatel EU-850D
ptk is offline   Reply With Quote
Old 04-25-2008, 12:24 PM   #32
Marvin Hlavac's Avatar
Marvin Hlavac will become famous soon enough
Thanks! That sounds (very) promising . My confusion stems from a piece of info I received from Garmin. If I interpret that info correctly (perhaps not, because I'm not familiar with various Garmin mapping products), then this is not supposed to work at all. Garmin Mobile PC is supposed to work only with the map data it comes with. Here's the link to the Garmin Mobile PC compatibility with other Garmin map products (post #65).
Marvin Hlavac is offline   Reply With Quote
Old 04-25-2008, 08:53 PM   #33
ptk
One more thing.
I couldn't get it work with gpsgate for now. Which is annoying as I can't use my gpsgate server tracking as well as my frontend.
Old 04-26-2008, 06:01 AM   #34
volke is an unknown quantity at this point
if you have a usb gps , you have to select a serial gps not a usb gps in mobile pc. i like it , but miss osk...
volke is offline   Reply With Quote
Old 05-01-2008, 03:58 PM   #35
ptk
just to give you an update.
As i mentioned, i deleted the NA map set that came with it and added a third party map. I was bored, so I decided to copy the world basemap set from my mobile xt plus added a bali routable map (also third party)
guess what, it works
so i have
gmapprom.img - my Singapore Routable map
gmapbmap.img - world base map
gmapsupp.img - Bali routable.
Old 05-01-2008, 08:19 PM   #36
These are all 3rd party (non-Garmin) maps, aren't they?
Old 05-02-2008, 01:21 AM   #37
ptk
the world base map is garmin's own
Old 05-03-2008, 11:23 AM   #38
darth sidious lite
Fiberoptic's Avatar
Fiberoptic will become famous soon enoughFiberoptic will become famous soon enough
I posted a review and some screen shots here:
http://www.mp3car.com/vbulletin/revi...-software.html
Fiberoptic is offline   Reply With Quote
Old 01-30-2009, 04:58 AM   #39
pons_saravanan is an unknown quantity at this point
how to configure GpsGate for garmin
hi
i am also using malsing maps with garmin mobile pc (trial). How did you manage to work with GpsGate. Can you please provide me some information here.
i managed to see the simulation. But now i am in the process of buying a USB gps recvr. Do i need to check for any particular specification while buying the GPS recvr.
thanks
pons_saravanan is offline   Reply With Quote
Old 01-31-2009, 03:22 AM   #40
ptk
Quote: Originally Posted by pons_saravanan View Post
hi
thanks
hi pon. i am kaomoo69 on ebay you could have just email me
Garmin mobile pc, as of the update couple of months ago, now works with gpasgate's virtual com port. just about ANY gps receiver will work as long as it puts out NMEA.
Old 01-31-2009, 07:51 AM   #41
Since version 5.00.50, GPSGate has worked with GMPC. If you do have this version (released Oct 2008), or newer, and if GPSGate is not working for you w/GMPC, then there is some other issue.
Garmin Mobile PC Bivio GPS 1 04-12-2008 08:11 PM
