Old 04-15-2008, 09:48 AM   #1
W3bMa5t3r's Avatar
Location: Washington, DC - Alexandria, VA N/W Area - NOVA
W3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of light
Thumbs up W3bIGCommFix - iGuidance CommPort Maintainer
I wasn't sure about "publicizing" the release of this app cuz I wasn't sure of the demand, so I was just gonna let folk stumble across it at carpcnet.com, but SonicXtacy02 suggested I create a thread for it... so here ya go.
I, like many others, use iGuidance embedded in RoadRunner. This is great, but when iGuidance "loses" it's Comm Port setting, it results in you having to open IG separately, set the Comm Port, then open it back up in RR, because the toolbar menu is stripped out with the embedding procedure.
This application will verify and if necessary set the Comm Port registry key for iGuidance.
Set the refresh time, comm port and auto-start settings. Can minimize to tasktray or taskbar.
Tested only with iGuidance NA 3.0
Grab it HERE
W3bMa5t3r is offline   Reply With Quote
Advertisement Sponsored links
Old 04-15-2008, 11:49 AM   #2
Raw Wave
lostreception's Avatar
lostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud of
glad to see you coding again now i need to do the same
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
lostreception is offline   Reply With Quote
Old 04-15-2008, 12:00 PM   #3
W3bMa5t3r's Avatar
word! maybe one of these days I'll finish up W3bTracker and my other projects lol. good to see ya around bro.
Old 05-26-2008, 11:44 PM   #4
jsee is an unknown quantity at this point
Man, this is exactly what I was looking for. For some reason, IG will loose the comport settings every so often. I will test it with IG V4 and will let you know the results. Thank you for posting it here!
jsee is offline   Reply With Quote
Old 06-17-2008, 11:47 AM   #5
W3bMa5t3r's Avatar
I'm a bit late, but glad to help...
Old 06-17-2008, 12:59 PM   #6
Toxic0n is an unknown quantity at this point
I found it will lose the COM port settings if the COM port is higher than 7 or so. I changed my COM port to 5 and have not had an issue since. Useful program nonetheless
Toxic0n is offline   Reply With Quote
iGMon - Solution for integration between iGuidance and Road Runner (I hope) b8bboi RR Plugins 570 11-05-2009 03:49 PM
How to setup iGuidance GPS for RoadRunner MatrixPC RR FAQ 31 05-22-2009 09:29 AM
Purdoom's big book of iGuidance apps! (Faq) PURDooM GPS 17 06-15-2006 01:46 AM
iGuidance Font Size Fix summary thread Viscouse GPS 29 03-28-2006 07:21 PM
Hacking Iguidance Peoples GPS 74 08-28-2005 07:40 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
