The MP3car.com Store
Thread Tools Display Modes
Old 04-22-2008, 05:57 AM   #31
Marvin Hlavac's Avatar
My Photos: (0)
* I'm not clear on if it's possible to use different Garmin (or non-Garmin, but Garmin-compatible) maps with this product. I'm trying to find out.
* I don't think Nuvi can output GPS signal via a cable, can it?
* I'm looking forward to reading if you guys manage to embed Garmin Mobile PC into your front-ends. Hopefully it will work. I just quickly looked if I can control this program with AutoIt, but to my disappointment it seems it may not be easy - or not possible at all. But there may be other (better) ways to control the program.
Marvin Hlavac is offline   Reply With Quote
Sponsored Links
Old 04-22-2008, 10:07 PM   #32
My Photos: (0)
Do any of you route your audio via bluetooth to your cars head unit? Everything works for me excpet Garmin Mobile PC. For some reason it only is playing through the UMPC speakers. It baffles me because all windows audio is piped through the bluetooth connection when the link is present..(except GMP) ...Any suggestions?
Steve
sgeorge1970 is offline   Reply With Quote
Old 04-28-2008, 01:42 PM   #33
_Dejan_'s CarPC Specs
Vehicle: 2004/Fiat/Stilo 1.9 JTD 160HP
My Photos: (0)
Im test software embedded in Centrafuse and is not usefull...
They are fix resolution and you can't change it...
_Dejan_ is offline   Reply With Quote
Old 04-28-2008, 01:51 PM   #34
My Photos: (0)
Try it with Full Screen mode of Centrafuse...hit the button between the keyboard and the X.
d0tech is offline   Reply With Quote
Old 04-28-2008, 01:56 PM   #35
My Photos: (0)
Im try this first but is same sh**
Old 04-28-2008, 02:02 PM   #36
My Photos: (0)
How did you get it to embedded into Centrafuse? It still open in full screen for me, its not embedded WITHIN centrafuse. It lays on top of Centrafuse.
Old 04-28-2008, 02:08 PM   #37
My Photos: (0)
Im in settings add new application then setup application name, path and window name. Fullscreen you must have off...
Old 05-05-2008, 07:13 PM   #38
jonessc's CarPC Specs
jonessc's Avatar
Vehicle: BMW 320D M-Sport
My Photos: (0)
Anyone know how to use .img (Garmin maps)? where to place in the folder? got UK maps (which arnt available) im using UK maps from other version of Garmin (supposed to be compatible)?
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
jonessc is offline   Reply With Quote
Old 05-06-2008, 12:11 AM   #39
My Photos: (0)
.img map you must put in garmin mobile pc folder. You must unlock it for your "device id"...
Old 05-06-2008, 02:27 AM   #40
Woofnstuff's CarPC Specs
Woofnstuff's Avatar
My Photos: (10)
yeah same question here
so just dump them in the root directory for the program?
eg c:\program files\garmin pc\
Woofnstuff is offline   Reply With Quote
Sponsored Links
Old 05-06-2008, 03:59 AM   #41
jonessc's Avatar
My Photos: (0)
the .img files are supposed to be unlocked?
CarPuter Progress:
Old 05-06-2008, 05:01 AM   #42
My Photos: (0)
You can unlock .img file if you in notepad create new file with name: imagefile.UNL where imagefile must be same as .img file. And you must paste into it your unlockcode which you are receive for your garmin pc...
Old 05-06-2008, 12:46 PM   #43
tn6478's Avatar
My Photos: (0)
use mapsource to load your maps. Maps has to be unlocked before you can install.
tn6478 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Garmin Mobile PC Bivio GPS 1 04-12-2008 07:11 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
