Old 04-22-2008, 03:14 PM   #1
lexdiamond20 is an unknown quantity at this point
No reception in NYC
Hope someone can help. Ok, my car pc has been working excellent the past year. The only problem is I loose the GPS signal when I get the areas of NYC with large buildings i.e. times sqaure, park ave, financial district etc. See it doesnt lose the signal and turn the car cursor from green to red in IG, but it turns yellow or red and jumos me from one road to the other on the screen. It even says im off the rad sometimes. Anyone else have this problem...please tell me you do. Im just about ready to get a new mouse. Just need to know if this problem is common.
This is the one I have:
http://cgi.ebay.com/Holux-USB-Mouse-...2em118Q2el1247
lexdiamond20 is offline   Reply With Quote
Old 04-22-2008, 03:36 PM   #2
Rick99TAWS6 is an unknown quantity at this point
Got enough 5V from your power supply - had similar issues myself, GPS would work and then not, upgraded power supply from M2 to DSATX and it seems to have cleared that up - think I was just a bit low on 5V with all the usb, etc
Rick99TAWS6 is offline   Reply With Quote
Old 04-22-2008, 03:58 PM   #3
Power is fine. Im using a 450 watt PS so I know tahts not the problem. Im not too keen on GPS specs. Can anyone tell from the Ebay link if the receiver is too weak to read through the high rise buildings in NYC. Im seriously thinking thats the problem.
Old 04-22-2008, 07:53 PM   #4
Marvin Hlavac's Avatar
Marvin Hlavac will become famous soon enough
That's a good receiver (based on the fine SiRFstarIII chip).
What you are observing is very typical behaviour of GPS navigation while driving among tall buildings in large cities. If you do a lot of driving in such areas, pretty much the only thing that you can do to improve the reception of the weak satellite signals, is to place your GPS antenna on the outside of your vehicle - on the roof. If you currently keep your GR-213 inside you car, you will observe substantial improvement when you place it on the roof.
If your GPS location still jumps from one street to the next, then when ever you find yourself in big city downtown, just switch from 3D map view / heading-up to 2D-view / north-up. That way the map will stop rotating senselessly, and you will be able to orient yourself easily, even while your GPS location icon happens to fly across buildings .
Marvin Hlavac is offline   Reply With Quote
Old 04-22-2008, 11:40 PM   #5
Thanks Marvin ill try that.
Old 04-22-2008, 11:45 PM   #6
skuller is an unknown quantity at this point
don't worry too much about it, it happen all the time.
the gps signal bouncing all over the tall building.
skuller is offline   Reply With Quote
Old 04-24-2008, 10:02 AM   #7
I see GPS systems in every other car in NYC. Are you saying theyre having the same problem? Highly doubt it.
Old 04-24-2008, 01:11 PM   #8
unless they have dead reckoning feature on their system, then yes they are having the same problem.
dead reckoning is overriding the gps signal if the signal is not making sense, with the sensor from speed of vehicle, heading (with gyro), etc.
Old 04-24-2008, 01:29 PM   #9
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
OEM nav units do use speed/direction that help.
But the biggest thing is put the puck on the outside. I had mine in my dash, in my trunk, and now on the top of the trunk. In the dash (up near the plastic facing up) and trunk (magnetic mount stuck to underside of same metal it is on now), reception was horrible. Would take 20 to 40 minutes to lock, and would lose signal in heavy tree areas, and large coverings. No skyscrapers here, maximum city ordered height is 13 stories I believe
As soon as I stuck it outside, instant lock on cold boot, and reception in the garage with the door closed, I never loose signal. 2mm of metal sure does make a difference!
Old 04-24-2008, 01:51 PM   #10
RipplingHurst's Avatar
RipplingHurst will become famous soon enough
My experience exactly. That's why I'm considering an external antenna. I can't figure out how to stick that GPS mouse (Garmin 18) outside. It is in my dash right now, at the skightest tree/building, I lose signal. Outside the car, perfect, it takes a very narrow street with tall buildings to block it. The roof is the best place by far, period: number of sattelites, speed of locking into them, precision, etc.
Worklog - 07 Infiniti Fx35 Carputer
Worklog – 06 Infiniti M35 Carputer (sold!)
RipplingHurst is offline   Reply With Quote
Old 04-24-2008, 01:56 PM   #11
2k1Toaster's Avatar
Well consider the $35 price on eBay of the 353 which is SirfIII as well and has a magnetic base with weatherproof enclosure, versus an external antenna to your current GPS puck and the time needed to solder them together...
We really do live in the age where it is cheaper to replace than to hack or repair.
Old 04-24-2008, 09:32 PM   #12
2k1Toaster said: "... the biggest thing is put the puck on the outside ..."
(The best antenna is the location.)
Old 04-24-2008, 09:35 PM   #13
Genesisfactor is on a distinguished road
go sirf 3. I go into manhattan all the time, never lost a signal. Even makes it a bit in the tunnels before losing signal, but as soon as you're out, your' back on track
In my carputer progress,the last pic i took had the gps in it. I don't even had an external antenna for it.
Carputer Progress: Here we go again...
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Join the fight against carputters. EMAIL ME!
Genesisfactor is offline   Reply With Quote
Old 04-25-2008, 09:23 AM   #14
Well I get a lock with 10 seconds of turning the PC on and almost instantly as soon as I leave the tunnels. Im not sure if the antenna is waterproof but I do know that it has a magnet to place on the outside of the car. I guess my only bet is to leave it where it is, under the rear window next to brake light, and just place it outside on the trunk when im headed to the city.
Thanks for the advice guys.
Indexing music in 1.0.9.8 Failed hovalistic StreetDeck 0 07-07-2007 12:19 PM
E46 Rubbish Radio Reception, whats the best fm tuner? Craggy General Hardware Discussion 0 05-18-2007 06:54 AM
Radio reception issue - 2001 Nissan Maxima fpb600 Car Audio 3 12-30-2006 04:19 AM
DigitalLife in NYC, Biggest Gaming Event of the Year digitallife2006 Off Topic 1 10-09-2006 10:08 AM
I lose FM reception with GPS on ... aoLhaTer GPS 0 05-17-2005 01:19 PM
