Old 05-05-2008, 08:35 PM   #1
lesterhung is an unknown quantity at this point
HELP! Garmin Mobile PC GPS 20x USB receiver
I need help here.
I have just received my Garmin Mobile PC with the USB receiver.
It keeps on saying "searching for satellites" for several minutes.
First I was in a house, then I thought I should go outside. Went out for 5 min, still nothing. Then, I decided to drive around town for 15 min, still nothing.
Last resort, I go to a OPEN area, where I can see the sky no matter where I turn. Yes, the sky is CLEAR with no clouds whatsoever. Still no signal. Then finally, it showed 1 stick of signal then it goes away.
The GPS unit is a 20x, and I believe it should be very sensitive.
Am I the only one that's having the problem? Should I call this a defective unit?
I've tried everything, unplugging, changing usb ports, rebooting, etc. NOTHING works!!!
lesterhung is offline   Reply With Quote
Old 05-05-2008, 10:10 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Check your COM port settings, namely baud rate.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 05-05-2008, 10:21 PM   #3
Can you shed more light on that?
I thought it is connected via USB. How do I get to the COM settings and what should I set it to?
Old 05-06-2008, 03:28 AM   #4
Woofnstuff's Avatar
Woofnstuff is an unknown quantity at this point
it will make an emulated com port
Woofnstuff is offline   Reply With Quote
Old 05-06-2008, 07:08 AM   #5
USB is a serial port.
There will be a USB-to-serial converter installed to read informtation from the gPS receiver.
Look in the device manager.
Make certain the COM port for the GPS receiver is set to 9600,N,8,1 in Device manager and in your application. (Note: If the manual for the receiver says something different, set the COM port to those settings.)
Old 05-06-2008, 08:25 AM   #6
The only item I see in Device Manager is "Garmin USB GPS".
I could not find anything about COM port.
The user's manual did not say anything about it either. Worst of all, it didn't even have a troubleshoot section!
Old 05-06-2008, 07:34 PM   #7
Woofnstuff's Avatar
drop these guys a question on their forum.
http://www.laptopgpsworld.com/pc-gps...s-reviews.html
or email garmin
Old 05-06-2008, 08:21 PM   #8
I contacted Garmin tech support earlier today.
They tell me to install an update, which I did and still nothing.
There is no such "COM port" setting that needs to be done according to Garmin.
They conclude that it is a defective unit. I have ordered a new one and returning this one. I will report back once I get the new toy.
or email garmin
Old 05-12-2008, 04:31 PM   #9
White Night is on a distinguished road
I had this exact problem with my system. I ended up putting the Garmin GPS on a powered USB hub, which fixed the problem. I also had some limited success switch USB ports.
White Night is offline   Reply With Quote
Old 05-12-2008, 04:57 PM   #10
I am getting the new unit today, so I will report back my findings.
I thought the USB port should have sufficient power for that tiny GPS. I don't have a Powered USB hub.
Old 05-12-2008, 07:52 PM   #11
I received a NEW unit today, and still NO SIGNAL!!!
What is the problem here?
I've tried it on HP tx1000 and Asus EEEPC, both no luck.
I've also updated the software to 5.00.10, which is the latest one.
I installed the software on my desktop and it won't even load.
Garmin Navigation software ported to PC - FINALLY! hd54321 GPS 16 03-18-2009 04:03 AM
CoPilot Software or USB GPS Receiver package Zip-Lock Classified Archive 5 05-13-2004 08:30 AM
Garmin 35 PC USB VS. Deluo USB Receiver SLAYER6669 GPS 0 10-03-2002 01:33 AM
