The MP3car.com Store
Thread Tools Display Modes
Old 05-07-2008, 11:18 PM   #1
shiltz's CarPC Specs
shiltz's Avatar
Vehicle: 2005 Dodge Magnum RT
My Photos: (0)
Reshacking Iguidance
So I decided to play around with reshacker to see if I could fix the problem with the arrow showing where you are showing that you are a good 100 feet or so further ahead of where you actualy are in the UMPC mode, I noticed that the normal version doesn't have this issue so I figured it had something to do with the way they scaled the image so I got the images from the standard exe install and put them into the UMPC exe and that did fix the problem unfortunatly before doing that the arrow was partialy under the text string telling you what zoom level your at and now with the smaller arrow it's completely under it, so my question is is it posible to move that text string or just outright remove it since it's useless anyways?
VIA MII10000, 512mb, EVGA MX4000, Xenarc 700TSV, M1-ATX PSU
30GB hitachi 2.5" HDD, Panasonic slimline slotload CDRW/DVD ROM
shiltz is offline   Reply With Quote
Sponsored Links
Old 05-07-2008, 11:22 PM   #2
pdegameplayer's Avatar
Vehicle: 1996 Mercury Cougar XR7 (Sport Edition) 4.6 v8
My Photos: (2)
well theres one way to find out try it reshacker makes a backup of the original file so you dont have to worry
LSX Void 3.3 Gauges Mod
pdegameplayer is offline   Reply With Quote
Old 05-08-2008, 08:26 AM   #3
shiltz's Avatar
My Photos: (0)
Well the problem is I have no clue where to look in reshacker, only knew how to do the images cause there was a guide for that.
Old 05-08-2008, 10:14 AM   #4
My Photos: (2)
mabey i can help what version of ig do you have?
and if you don't mind to upload the main exe and pm me the link i can possibly fix it for you and explain how i did it. that should help you out tremendously also if you don't want to do that - to change variables look in the dialog or string data labels and just tinker around
Sponsored Links
vB code is On
Trackbacks are Off
How to setup iGuidance GPS for RoadRunner MatrixPC RR FAQ 24 04-02-2008 01:47 AM
iGMon - Solution for integration between iGuidance and Road Runner (I hope) b8bboi RR Plugins 567 10-07-2006 09:52 PM
Purdoom's big book of iGuidance apps! (Faq) PURDooM GPS 17 06-15-2006 12:46 AM
iGuidance Font Size Fix summary thread Viscouse GPS 29 03-28-2006 06:21 PM
ResHacking iGuidance Cheat Sheet d_sellers1 GPS 5 06-24-2005 04:58 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
