Reshacking Iguidance
So I decided to play around with reshacker to see if I could fix the problem with the arrow showing where you are showing that you are a good 100 feet or so further ahead of where you actualy are in the UMPC mode, I noticed that the normal version doesn't have this issue so I figured it had something to do with the way they scaled the image so I got the images from the standard exe install and put them into the UMPC exe and that did fix the problem unfortunatly before doing that the arrow was partialy under the text string telling you what zoom level your at and now with the smaller arrow it's completely under it, so my question is is it posible to move that text string or just outright remove it since it's useless anyways?
VIA MII10000, 512mb, EVGA MX4000, Xenarc 700TSV, M1-ATX PSU
30GB hitachi 2.5" HDD, Panasonic slimline slotload CDRW/DVD ROM
