Old 06-11-2008, 06:54 AM   #1
GPS wont connect
Hi Folks,
I’m using CF and have a BU-353 gps, but I cannot get it to lock onto any Satellites under Destinator.
It works perfectly on oziexplorer and with the proprietary software supplied. What am I doing wrong?
CF sees the correct COM port by default, using NMEA and the baud rate is the same as the other two apps.
Have I missed something?
Cheers
MrZubey is offline   Reply With Quote
Old 06-11-2008, 08:07 PM   #2
Hello,
Hopefully I'm answering my own question, can someone please confirm whether you need to load the Destinator SDK to get satellite connection. Or does CF actually include the frontend to do this?
Thanks.
Old 06-13-2008, 04:14 AM   #3
I will ask my friend. He can do it.
thomasz is offline   Reply With Quote
Old 06-13-2008, 10:42 PM   #4
Thanks for your answere!
So then does anyone have any ideas why under CF wont lock onto the Satellites yet all my other apps will??
Is there anyway "to see" whats going on with the communications between CF & the GPS unit?
Cheers
Old 06-14-2008, 02:05 AM   #5
You might have to run xPort3 so that Centrafuse and your GPS software both have access to the NMEA sentences on the port.
Ampie Case
2.5" Hard Drive 80GB Toshiba 5400rpm
Kingston 512 MB DDR RAM PC3200
Xenarc 700TSV - VGA Monitor
VIA EPIA M10000 Mini-ITX Mainboard
M1-ATX 90 Watt - Smart Power Supply
2005 Honda Civic
Maheriano is offline   Reply With Quote
Old 06-14-2008, 04:00 AM   #6
Hey Maheriano,
If your ever downunder I owe you a beer mate!
Your spot on, installed xPort and CF found the extra com port I added in xPort and she all works perfectly.
Thanks again
Old 06-14-2008, 06:11 PM   #7
Quote: Originally Posted by MrZubey View Post
Hey Maheriano,
Thanks again
No worries, one of the most entertaining nights of my life was with a fella from Perth so consider us even!
Ampie Case
2005 Honda Civic
Attention Newbies! Everything (almost) you want to know about GPS (Part 1) Bugbyte GPS 56 11-16-2008 12:10 AM
Connect GPS port at resume ? Eminos Road Runner 13 05-07-2007 06:31 PM
Alturion Professional Advanced GPS 6 - The New D3 ? Is There A SDK ? ccsnet GPS 91 11-07-2006 05:47 PM
Connect GPS message in Routis Zoltan Software & Software Development 14 09-18-2004 07:50 PM
