Old 06-18-2008, 05:13 AM   #1
problem with gps hibernation-resume
hi
i have usb gps and it works ok but when i put in hibernation and resume it doesn't works.
i have to disconnect, wait 1 minute and reconnect.
i read lots of posts, try different method but nothig.
someone can help me?
i try xport but nothing
botti206 is offline   Reply With Quote
Old 06-18-2008, 05:20 AM   #2
Fusion Brain Creator
2k1Toaster's Avatar
which "different method"s did you try?
Have you tried any of the program made to do the disconnecting reconnecting for you already?
Old 06-18-2008, 05:24 AM   #3
i try xport
and i try a bat file that delete and reinstall the device every startup
what program do you say?
very thanks
Old 06-18-2008, 08:45 AM   #4
Curiosity's Avatar
Is it on a USB hub with something else?
XPort 1.26 -GPS port splitter, logger, and USB device resume fix
Curiosity is offline   Reply With Quote
Old 06-18-2008, 01:45 PM   #5
no , it is connected directly to usb port
Old 06-18-2008, 02:29 PM   #6
Curiosity's Avatar
Oh that's odd. Have you tried a different port? It probably won't help.
If you hibernate without running anything then start up your nav program (or frontend that uses a GPS) and it works, then that's normal. If it still doesn't work, then that's more of a driver/hardware issue. For the first you can use XPort with nothing selected at the bottom. For the latter, select the GPS in the list.
Old 06-19-2008, 01:40 AM   #7
ok i will try but i use its drivers but after hibernation dosn't work
other ideas?
Getting Started with GPS grepzen The FAQ Emporium 12 09-26-2006 05:54 AM
MediaEngine Freezes after hibernation if using GPS? XxAndyxX Media Engine 3 12-21-2005 09:43 AM
iguidance resume for usb gps receivers kuo PV Bugs 3 02-14-2005 12:48 PM
Problem with GPS probably voltage GReeToZ General Hardware Discussion 9 10-26-2004 01:26 PM
