Old 06-19-2008, 10:19 AM   #1
SiRFInstantFix on PCs?
Hi all,
Many of you probably already know what SiRFInstantFix is. To those who don't know... it is an offline A-GPS system for the Sirf-III chipset (i.e. get a GPS lock within seconds instead of minutes by using data downloaded from the net).
However, I've only seen it working on PNA devices. Does anyone know whether it can possibly be used on PCs with a bit of hacking or manual intervention?
Thanks.
wywywywy is offline   Reply With Quote
Old 06-19-2008, 12:52 PM   #2
v8 scimitar's Avatar
I know what your on about as I have it on my HTC but what your describing wasnt my understanding of what it was for. I thought it was for pda type devices due to them not being so sensitive therefore took ages to get a lock. Assisted GPS is no where near as good as the full fat stuff and my HTC doesnt get a lock as quickly as my car PC. Htc without the software takes ages to lock so it definately works but still not as good as a proper GPS reciver. From stone cold my car gets a lock in about 30 seconds, from warm about 10, instant if I leave it powered which is most of the time.
Visit my site V8 Scimitar
SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit.
v8 scimitar is offline   Reply With Quote
Old 06-19-2008, 12:54 PM   #3
AGPS works in conjunction with the normal GPS mate.
It assists the GPS not replace it.
Old 06-19-2008, 02:21 PM   #4
ummm yes thats what I typed that's why its called assisted GPS. Its to assist poor/low power receivers not proper receivers like you would have in a car.
Old 06-19-2008, 05:16 PM   #5
Okay we have different views.
My view is that it is to accelerate first-fix and to help poor signal conditions/locations. A Sirf-III is a Sirf-III, there is no difference between a Sirf-III in an HTC phone or in a car GPS receiver - they are all proper.
Incidentially, in my HTC (its a Touch Cruise) it uses Qualcomm's GPSone chipset, and this chipset is commonly regarded as inferior to Sirf-III.
Old 06-21-2008, 04:53 PM   #6
Marvin Hlavac's Avatar
While the chip of the GPS receiver may be identical, the antenna may be completely different. The GPS antenna in a small PDA phone is very tiny in comparison to one in for example USB GPS unit such as BU-353. So the small PDA phone can use the help of AGPS much more than a CarPC with a GPS receiver with a larger antenna.
Marvin Hlavac is offline   Reply With Quote
Old 06-21-2008, 05:04 PM   #7
There is also a large difference in the amount of power available. If you ran a USB receiver on a pda phone the battery life would be terrible.
1992 - VW Caravelle Project flodulv Show off your project 5 07-30-2007 06:14 PM
Newbie, but not to PC's happyjacky Newbie 1 03-10-2007 01:14 AM
Ultra mobile PCs? wayland1985 Newbie 0 01-14-2007 12:44 AM
HP Embedded Thin PCs..... camsgs3 General Hardware Discussion 9 03-31-2005 01:06 AM
Confused about shuttle PCs vs via processors clean customs Newbie 14 03-04-2005 09:13 AM
