Old 07-01-2008, 03:01 PM   #1
CF GPS Card on Commell LV-671 - help
Hi,
I have a Holux GM-270 and I cannot get XP, LinuxICE or CentOS to recognize the card. The card does still work in another device so I can verify that it is functional, but I would like to use it on the computer for obvious reasons. The PCMCIA controller also appears to be working correctly.
Has any one had luck with this combination? Perhaps there is something I am missing in the BIOS?
I did change the CF Address setting (JCFSEL) jumper on the mobo from master to slave
any help appreciated.
frndrfoe is offline   Reply With Quote
Old 09-16-2008, 03:02 AM   #2
Hello frndrfoe,
It simply won't work that way. the CF slot is really an IDE-only slot. It is only wired to the IDE controller and not to the PCMCIA controller at all, so any IO cards won't work, only CF flash cards (up to any size, that is an advantage though)
You will need a PCMCIA--> CF adapter to get the card working, and plug it in the PCMCIA slot. That should work, if supported at all.
journeyman is offline   Reply With Quote
Attention Newbies! Everything (almost) you want to know about GPS (Part 1) Bugbyte GPS 56 11-16-2008 12:10 AM
How to Embed any GPS program into Road Runner jonessc RR FAQ 30 11-13-2008 01:41 AM
Can't hibernate after transfer to CF card blkwrx Operating System Optimization 3 02-08-2007 08:47 AM
Getting Started with GPS grepzen The FAQ Emporium 12 09-26-2006 06:54 AM
Autorun CF card on insert??? Ill1 General MP3Car Discussion 4 07-09-2004 10:19 AM
