Old 07-08-2008, 06:06 PM   #1
Operating a BT receiver without the battery
Is it possible to operate a Bluetooth GPS Receiver (e.g. BT-Q818) using a USB/Power cable without the use of an internal battery. Currently if the battery is removed the unit will not power up even if connected to the mains.
Would like to have the unit operate (on/off) only when an external power-source is available e.g. when hooked up to the car this will allow me to start/stop the GPS unit by turning the car's ignition switch.
nb. i know some GPS units have auto on/off, functionality but id rather save some money by modifying my existing unit, disassembled pictures attached:
Roy33 is offline   Reply With Quote
Old 07-09-2008, 11:47 AM   #2
Would connecting the (+) and (-) do the trick?
Old 07-09-2008, 11:51 AM   #3
Raw Wave
Tidder's Avatar
Not unless you have a 3.7v power source to hook to the (+) and (-). USB is 5v. Computers do have a 3.3v typically, but for simplicity's sake, why not just leave the battery?
Tidder is offline   Reply With Quote
Old 07-09-2008, 12:09 PM   #4
If i leave the battery it will charge as i drive and keep the GPS receiver active for 12+ hours after i switch off the car.. so will continue to broadcast Bluetooth..
and i don’t think its possible to stop the battery from charging...
Old 07-09-2008, 12:19 PM   #5
I would just build a regulated 3.7v power supply and nix the battery.
phuz is offline   Reply With Quote
Old 07-09-2008, 12:19 PM   #6
I was faced with a similar issue as I have a globaltop g33 which has auto-off but not auto-on. I made a simple circuit using a relay, a couple diodes, resistor, led's and some capacitors. When the computer turns on, it flips the relay and turns on the BT gps receiver, when the computer turns on, the caps drain and flip the relay again and turn it off. USB cable plugged into the usb port for charging the battery when computer is running and the relay is connected to the on/off switch of the gps receiver.
I found the schematics on this site, but don't have time to search right now. If I get a chance later I'll do some searching as it would be your best option. That way you can have a 'warm' start for gps signal aquisition while not worrying about it staying on or not turning on.
nst6563 is offline   Reply With Quote
Old 07-09-2008, 12:38 PM   #7
Raw Wave
Tidder's Avatar
Or could simplify even more by just using a relay hooked to the usb 5v and in between the battery and device on the positive lead.
Old 07-09-2008, 04:37 PM   #8
I would also be interested with the scheme.
I tried to search but can't find one.
skuller is offline   Reply With Quote
Old 07-09-2008, 11:27 PM   #9
JimmyFitz's Avatar
My first carPC implementation had a Royaltek RBT3000 GPS unit. It was similar in that it had its own battery with a charger and it had a hardwired on/off switch. I installed it in the trunk and connected its charger to constant 12V. The current draw from this device was minimal and even less, once the battery got fully charged. Yes, the Bluetoooth radio was always on, which would allow someone to "Bluejack" my GPS. What would it tell them other than give a current location of the car, which they already know anyway because they must be within 30' to connect. I later changed to a BU-353 to get newer technology SiRF.
2002 T-Bird, Via SP13000, Travla C158, M1-ATX, 1GB RAM, 120GB 2.5" drive, SlimSlot DVD-RW, XP, RR, Winamp, Xenarc 700TSV, HTC Touch PPC/Phone, BU-353 GPS/iG3, Elmscan OBDII, Griffin PowerMate, 2 Blaupunkt amps, Polk spkrs, 5 sec startup/S3 STR
~Jimmy
JimmyFitz is offline   Reply With Quote
Old 07-10-2008, 03:29 AM   #10
I had this problem with my Dell Bluetooth reciever. If I left the unit on however, it got very upset and would randomly turn off.
In the end I just disconnected the battery, and it worked fine. The only problem is the unit is an older one and has a rubbish cold start time. Matter of fact the unit has become a bit of a liability. (Likes to track down the wrong roads these days and excels at getting me lost)
I was looking at a new USB device, as my understanding was that they would only pull power from the the CarPC negating this issue. Does anyone know of a good unit, (Ideally Sirf Star 3 chipset), with the standard jack for my external GPS antennae?
Badgerboy is offline   Reply With Quote
Old 07-10-2008, 10:04 AM   #11
Found the post where I got my circuit from.
http://www.mp3car.com/vbulletin/249253-post9.html
It's basically a combination of the Delay On and Delay Off.
I'll have to take the carpc apart this week/end so I'll pull the circuit out and draw up a diagram as best I can. I'll take a picture as well. But be warned, it's a mess but it works great
What kind of cap/amp? asong31 Car Audio 60 12-26-2006 01:30 PM
2nd Battery, Wiring Idea. jmcclure22 Newbie 2 11-19-2006 10:51 PM
Replaced Motherboard battery now no post?? BADDERICK General Hardware Discussion 8 07-08-2005 02:34 PM
All-In-One COTS Solution: AC/DC, Battery, etc. Pwrplayer Power Supplies 4 01-25-2005 10:01 PM
MPJA - MECI ASTEC DC-DC Converter Luc General Hardware Discussion 39 11-22-2004 09:31 PM
