Old 11-26-2008, 04:25 PM   #1
LCat is an unknown quantity at this point
Best GPS USB reciver - $$ is not an object
Of course it allways is but we could spend up to $200 on the GPS reciver in this project
LCat is offline   Reply With Quote
Old 11-26-2008, 06:29 PM   #2
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
This really is a ridiculous question.
Why don't you try spending some time reading in the forum rather than just asking someone to tell you. Better yet, why don't you just go and purchase a complete solution from one of the many CarPC retailers. If you don't want to take the time to understand why you are going with each and every solution in your set-up, then it's the best option.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 11-26-2008, 08:42 PM   #3
I'm not purchasing compleet solution cuz none of the compleet once have many things I require - full size PCI slot for a Lynx card, solid state HD, bit perfect software, etc......
Old 11-28-2008, 10:22 AM   #4
WuNgUn's Avatar
WuNgUn is on a distinguished road
GPS mouse is a good one...available at the store!
WuNgUn is offline   Reply With Quote
Old 11-28-2008, 10:14 PM   #5
GPS Mouse - lol
Old 11-28-2008, 10:16 PM   #6
Oh - you meant G.Mouse - BT353 - kind of on top of my list
Was wondering if anything outpreforms it
Old 11-29-2008, 12:09 AM   #7
mx270a's Avatar
mx270a is on a distinguished road
I'd go with the Trimble 252. They start at $3000 for the WAAS version, $5000 for OmniStar XP/HP capability, or $7000 for dual frequency RTK support. Position updates at 10 Hz with an accuracy of under one inch.
If you can wait a couple months, I've heard they are coming out with a new version that will probably add GLONASS support.
You did say $ is not an issue.
mx270a is offline   Reply With Quote
Old 11-29-2008, 02:39 AM   #8
Well - if you read this post you would have seen - not an issue up to $200. Now if we were talking about pice of audio eqipment - well you just mentioned about 1/8th of the retail of my audio system Also not sure why knowing my position to an inch would help me on the road. Precision is good but I do not think we need it to more then to couple of feets at best. Now speed of aqusition, relaiability in the city, overall relaiability - thats important
Old 11-29-2008, 08:30 AM   #9
_
This ALL depends on how well you want it integrated. Again, a few reads through a few threads will tell you a ton about which GPS receivers are top on people's lists.
If you want it 100% integrated, the GPS mouse isn't the way to go.
Jan Bennett
Old 11-29-2008, 09:33 AM   #10
bridqer's Avatar
bridqer is on a distinguished road
After killing a few gps mouse receivers with wet weather and usb problems, I use a Garmin OEM 16 HVS High-Sensitivity $93. Gamin also has the Garmin GPS 18x 5Hz High-Sensitivity for $140 for something more accurate.
'99 F-350 Crew 7.3L~'02 F-350 Crew 7.3L~ '04 Dakota SLT+ 4.7L
MII12000opus120~MII12000opus120~MII10000opus150
NA~Senao dual 7.4 ant~Orinoco Gold
Pioneer~Pioneer~PG Octane-R R5.1MT
Xenarc, Rikaline6010, Garmin OEM16 HVS, CoPilot10
bridqer is offline   Reply With Quote
Old 11-29-2008, 10:08 AM   #11
WuNgUn's Avatar
Just don't try to run it thru quality window tint...you won't get a signal.
Old 11-29-2008, 02:17 PM   #12
Has to be an ouside unit - I have a acoustic leaded glass with bluesh tint(standart on my car) which screws up GPSes very well
Old 11-29-2008, 02:19 PM   #13
That Garmin GPS 18x 5Hz looks intresting - how's startup times and behaivior in the city
Old 11-29-2008, 02:28 PM   #14
Qiuick question - I'm not sure I need precision of the 5 HZ one - is regular Garmin GPS 18 USB a good reciver(easier to integrate). Like Ive sad my criterias are good resolution, fast lock and behavior round tall building.
How to Embed any GPS program into Road Runner jonessc RR FAQ 52 10-28-2009 12:10 PM
garmin mapsource and usb gps mouse thecrow GPS 9 09-26-2006 03:24 PM
earthmate usb gps with MS Streets&Trips? liquid_smoke GPS 17 11-27-2004 09:45 PM
D3 with USB GPS after HIBERNATION BOND007BE Map Monkey 7 11-26-2004 02:54 PM
Bug Reports frodobaggins FrodoPlayer 168 10-16-2004 01:25 AM
