Old 12-31-2008, 03:24 AM   #1
smhussain is an unknown quantity at this point
GPS needs 2-3 minutes to lock onto satellite
I have a satglobal Bu-353 gps receiver linked to garmin mobile pc software. As soon as i turn my gps receiver garmin starts showing two signals (out of five) but in this state the gps does not work and garmin says "searching for satellites".
It takes about 2-3 minutes for the gps to obtain a lock.
Can somebody help.
smhussain is offline   Reply With Quote
Old 12-31-2008, 03:58 AM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Can somebody help.
where's the puck located? Can it see the sky directly with the top facing up?
Old 12-31-2008, 04:48 AM   #3
In rear window of my rx8
Old 12-31-2008, 04:53 AM   #4
2k1Toaster's Avatar
You have tint? I know my car has tint that is somewhat metallic, so GPS doesnt work well inside pointing through the window. If you put it outside does it work? That would narrow it down to what the problem is.
Old 12-31-2008, 05:42 AM   #5
Okay wil lcheck it.
Old 12-31-2008, 10:39 AM   #6
Minoritydan is an unknown quantity at this point
Heh, my Garmin now takes 20 mins to lock!
Minoritydan is offline   Reply With Quote
Old 12-31-2008, 11:43 AM   #7
Machinehead's Avatar
Machinehead will become famous soon enoughMachinehead will become famous soon enough
2-3 minutes isn't really an issue, that's pretty normal for a BU-353.
Machinehead is offline   Reply With Quote
Old 12-31-2008, 03:47 PM   #8
Kalenth's Avatar
Kalenth is infamous around these parts
Really? Is that software related? I use a 353 and iGuidance... puck in the front right corner of my F150 with clear sky view, and it gets signal fairly instantly.
Kalenth is offline   Reply With Quote
Old 12-31-2008, 04:01 PM   #9
2k1Toaster's Avatar
Well substitute front right corner of F150 to rear left back of Civic.
The BU-353 has a built in battery to keep hold of satellite positions when off. So as long as it had a lock before it turned off, it should get a lock really fast the next time. Assuming you didnt move the puck without it being on, in which case it dumps what it thought it knew and tries to lock again from scratch.
Mine locks as soon as I get out of the garage.
Old 12-31-2008, 04:37 PM   #10
rgarjr's Avatar
rgarjr is an unknown quantity at this point
Yah, the BU-353 is very good for locking n loading the birds, such a nice little puck.
My carpc worklog
rgarjr is offline   Reply With Quote
Old 01-09-2009, 12:12 PM   #11
Crawdaddy is an unknown quantity at this point
I've been having trouble getting locks onto the birds with my bu-353. It often takes a good deal of time if it locks at all. However, I have it sitting on the front dash of my suburban, which is a near-vertical windshield. I will try putting it on the roof of the truck. These bu-353 pucks have a magnetic base and are weatherproof, aren't they? So I can put it on the roof permanently? Thanks for the help.
Crawdaddy
1991 Chevy Suburban 1500 w/SBC 350
2005 Saturn ION 2 sedan
Suburban Worklog
"A local New Orleans man says his socks are finally dry..." -Tom Tucker, Family Guy
Crawdaddy is offline   Reply With Quote
Traffic Cams International v1.3.0 (1.4 Beta available) Enforcer Other Cool Stuff 673 11-06-2009 02:30 PM
Attention Newbies! Everything (almost) you want to know about GPS (Part 1) Bugbyte GPS 65 10-13-2009 07:51 PM
W3bLock - Screen Lock w/ GPS Tracking W3bMa5t3r RR Plugins 4 07-17-2008 09:09 AM
Getting Started with GPS grepzen The FAQ Emporium 12 09-26-2006 06:54 AM
earthmate wont lock onto satellite aoLhaTer GPS 10 06-12-2003 11:58 AM
