Old 01-25-2009, 03:27 AM   #1
aznd000d is an unknown quantity at this point
program to prime GPS right when the computer starts
Been reading around but couldn't find the answer for this.
Is there a program that would run and lock to GPS satellites right when windows log on? So that my position is available whenever I run NAVI; instead of running NAVI when I need it and wait for a fix on the satellites.
I'm doing the Centrafuse trial right now, and I notice that GPS receiver will only begin to get a fix when I click the Iguidance button. But then I would need to wait for the satellites to lock into position.
Thanks.
aznd000d is offline   Reply With Quote
Old 01-25-2009, 04:48 AM   #2
wait a min.......I think I found my answer....XPort....is this it?
Old 01-25-2009, 04:58 AM   #3
rgarjr's Avatar
rgarjr is an unknown quantity at this point
The GPS device should start locking satellites whenever it receives power from the USB.
My carpc worklog
rgarjr is offline   Reply With Quote
Old 01-25-2009, 05:06 AM   #4
I have a bluetooth GPS receiver though.
Old 01-25-2009, 09:47 AM   #5
Marvin Hlavac's Avatar
Marvin Hlavac will become famous soon enough
...yes, xport, or gpsgate, should do the trick.
Marvin Hlavac is offline   Reply With Quote
Old 01-26-2009, 01:30 AM   #6
tom_rosenback's Avatar
tom_rosenback is an unknown quantity at this point
Shouldn´t the GPS receiver get "fix" position (cold start) a short while after it has been powered up? At least my USB receiver does, without needing to start the nav software (or XPort).
What I would like to have is that it would get fix position directly after power up, like some handheld GPS´s do, also some Nokia phones have this, I think it is called AGPS on them.
tom_rosenback is offline   Reply With Quote
Old 01-26-2009, 12:17 PM   #7
CabrioBob's Avatar
CabrioBob is an unknown quantity at this point
It may be possible to create system where your GPS mouse stays powered on even when the PC is powered off.
With a solar panel, chargable batteries, a relay and the GPS mouse.
PC OFF mode :
Relay cuts off the connection between the GPS mouse and carputer.
Daytime (sun is shining) : solar panel provides power to the GPS device and charging the batteries.
Night time : batteries are charged and provides power to the GPS mouse.
PC ON mode :
Relay cuts off connection between GPS mouse and batteries / solar panel, batteries will still be charged by the solar panel (or: batteries charged by carputer).
GPS mouse is operated by carputer conventionally.
The above are only thoughts I have had in the past, don't even know if it's doable
but small solar panels are affordable these days so maybe someone else might want to dig deeper into this.
solar panel example
(assuming GPS mouse will also operate @ 5.5V)
CabrioBob is offline   Reply With Quote
RR gps program with Australian maps?? Moby58 Road Runner 16 11-23-2008 08:35 PM
Track my car? Computer + GPS Unit + Internet gpsforcar GPS 13 01-15-2008 05:29 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
