Old 03-17-2009, 12:36 AM   #1
mskrzat is on a distinguished road
Xport Disappearing ports problem.
When I installed xport I didn’t realize it auto started on it own so I put a copy of it in the startup folder. I realized my mistake after a little reading and its working great now. But now the ports I started out with (ports 4&5) no longer show up in the output port select pull down. I tried uninstalling Xport and deleting the Xport registry entry then reinstalled Xport. But still no option for port 4 or 5. Where does xport store this info?
Mike
mskrzat is offline   Reply With Quote
Old 03-17-2009, 07:59 AM   #2
WuNgUn's Avatar
WuNgUn is on a distinguished road
Just output to different port numbers and reconfigure your devices to use these new ports...
Possibly something you instaled took those ports, i.e. my BT dongle ALWAYS takes COM3 and 4...
WuNgUn is offline   Reply With Quote
Old 03-17-2009, 01:52 PM   #3
This happened twice so I’m missing 4 ports. Each time it happened only the ports that xport was using disappeared that’s why I believe it’s xport. Port 2 is the only one left below 10 and I’m using that with IG because it won’t remember any ports higher than 9.
It’s working great now but it would be nice to get the lower ports back.
Old 03-17-2009, 03:19 PM   #4
What can I say? I like serial.
Curiosity's Avatar
Curiosity will become famous soon enough
XPort doesn't save the information anywhere, but it does allocate them in the port arbiter. Anything can go wrong though, and it fails once and leaves those allocated. Hitting the Scan button would fix it. I actually changed all that a week ago so that it doesn't rely on the info but still keeps it up to date. I replaced 1.28 with it on my site and didn't bump the version number.
XPort 1.41 -GPS port splitter, logger, and USB device resume fix
GPS DirectShow Filter / XOBD / MiniCam
Curiosity is online now   Reply With Quote
Old 03-18-2009, 12:22 AM   #5
Thanks Curiosty, that did it.
Tags
ports, xport
xport + AyAy Sir crash problem. Punky GPS 14 07-24-2008 02:30 AM
Usb ports on Morex Case problem volum3rider General Hardware Discussion 5 11-14-2005 07:25 PM
had an all day (9 hr) problem at work.... wizardPC Off Topic 13 10-20-2005 12:50 PM
Lilliput TouchKit problem solved! AAVfReaK LCD/Display 2 10-16-2004 04:51 PM
Some warnings about Deluo Routis 2004, MapPoint 2004 & XPort dumpper GPS 13 07-15-2004 01:07 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
