Old 05-17-2009, 02:01 PM   #46
lambosprit's Avatar
lambosprit is on a distinguished road
Ok. New release available. Major changes so haven't removed old version. Would appreciate people testing to see if it works ok so I can remove the old version.
see first post for new stuff
lambosprit is offline   Reply With Quote
Old 05-17-2009, 02:33 PM   #47
mightycrown is an unknown quantity at this point
just one thing, i m not familiar with GPS tracking, does my car need to be staying online(internet) to be tracked? or it will work when the carpc is not on internet
mightycrown is offline   Reply With Quote
Old 05-17-2009, 03:38 PM   #48
lambosprit's Avatar
the car is tracked all the time and its position is stored in an xml file. When you get a network connection (either through the internet or through a wireless network connection i.e. your home network) it automatically connects and loads the stored positions into the server.
So no you dont need internet all the time but you do need a network connection at some point to upload the data to the server.
Old 05-17-2009, 03:49 PM   #49
hondabldr is an unknown quantity at this point
Coo Ill try it out as soon as I get a free min tonight GREAT WORK AS ALWAYS!!!
hondabldr is offline   Reply With Quote
Old 05-17-2009, 04:18 PM   #50
thanks man! it sounds awesome, i will try it out. great work.
Old 05-21-2009, 03:44 AM   #51
Ok been testing it out, The client side crashes on me when i resume half the time, when it doesnt crash I still have to stop and start the gps to get it to update to the server, It keeps pulling gps data fine after resume just wont update the server... The last version resumed fine, and pulled gps data fine after resume it just would not update the server
Old 05-21-2009, 08:49 AM   #52
lambosprit's Avatar
can you post the debug log please
Old 05-22-2009, 04:04 AM   #53
TimmyM's Avatar
TimmyM is on a distinguished road
I finally got this installed. Still haven't gotten it working quite right yet, still need to play with it a bit.
One problem is I got an error from the client about not having the correct IP address I think it was. I didn't put in my IP address, instead I put www.mydomain.com. Will that work or will I need to put the actual IP address in? Will I need to change it every time my IP changes?
I use webcamXP running some security cameras. It's suppose to send me an SMS through here, http://textu.org. So far I haven't been able to get that part to work but I was thinking it might be an option instead of using skype.
TimmyM is offline   Reply With Quote
Old 05-22-2009, 12:37 PM   #54
lambosprit's Avatar
The ipaddress is in two part. The external address must be a fixed address and is the one that tells the web how to find your server.
The internal address is how you find the server on your own home router network.
As far as I knew a web address should work as long as you have port forwarded to your server.
Old 05-22-2009, 12:38 PM   #55
lambosprit's Avatar
Anybody tried the geofencing yet? Can't test for real myself because I'm travelling so dieing to know if it does.
Old 05-23-2009, 11:40 PM   #56
Im just figuring out the geofencing now so ill let you know soon.. One thing thats kinda annoying whenever i move the map around it pops up this error
" IS Point Within Polyline: false" I keep having to click ok..
This is my debug, I started it up let it track then hibernated and right when i resumed it crashed
5/24/2009 3:11:17 AM:C:\Documents and Settings\Administrator\Desktop\GPSClient\gpstracke r.ini
5/24/2009 3:11:17 AM:GPSTracker client version :1.2.0.0
5/24/2009 3:11:17 AM:External Server IP address is xxxxxxxxxxxxx
5/24/2009 3:11:17 AM:Internal Server IP address is 192.168.1.115
5/24/2009 3:11:17 AM:Home SSID is linksys
5/24/2009 3:11:17 AM:Server port is xxxx
5/24/2009 3:11:17 AM:Server pingable is True
5/24/2009 3:11:17 AM:Client will send GPS co-ords every 5Secs
5/24/2009 3:11:17 AM:Client will try to resend GPS co-ords every 5 Secs when no network connection
5/24/2009 3:11:17 AM:User ID is CIVIC
5/24/2009 3:11:17 AM:Wake on Lan disabled
5/24/2009 3:11:17 AM:Speed multiplier set to 1.150779
5/24/2009 3:11:17 AM:GPS com port set to COM15
5/24/2009 3:11:17 AM:GPS baud rate set to 4800
5/24/2009 3:11:17 AM:GPS data bits set to 8
5/24/2009 3:11:17 AM:GPS data bits set to 50
5/24/2009 3:11:18 AM:Resend complete
5/24/2009 3:11:35 AM:StatusChange
5/24/2009 3:12:35 AM:StatusChange
5/24/2009 3:13:05 AM:StatusChange
5/24/2009 3:13:51 AM:StatusChange
5/24/2009 3:14:35 AM:StatusChange
5/24/2009 3:15:35 AM:StatusChange
5/24/2009 3:16:16 AM:StatusChange
5/24/2009 3:16:18 AM:Suspend
5/24/2009 3:16:18 AM:StatusChange
5/24/2009 3:19:24 AM:Resume
5/24/2009 3:19:24 AM:StatusChange
Old 05-24-2009, 03:14 AM   #57
lambosprit's Avatar
Yeh. I noticed i left that debug in. I've already removed it.
I'm hopeing you've changed the ipaddress and port in debug to hide your identity rather than not actually having set them.
I have some time today when I can actually use my gps so will work on fixing this. Also putting together a proper installer as I've just figuired out how o do that as well.
Old 05-24-2009, 07:54 PM   #58
monzablue16v is on a distinguished road
This looks really promising will download it and have a play with it on the laptop
monzablue16v is offline   Reply With Quote
Old 05-24-2009, 10:18 PM   #59
Yes sir! Not about to post my address to my server to world lol :-p
Old 05-25-2009, 07:21 AM   #60
lambosprit's Avatar
I've fixed what I think was the bug but because I was running both the tracker and the server on my laptop and it kept changing my ipaddress after hibernating I couldn't test fully.
I've also made an installer that should find the ini file setup you currently have and reuse it, IF its in the same install directory.
Get it on the first post.
Any feedback is welcome as allways
it works.. auto syncing when you arrive home collegeboyslive General MP3Car Discussion 4 11-29-2007 07:36 PM
Home stasik-a4 Map Monkey 1 06-01-2007 01:55 AM
Image server qwertylol Software & Software Development 1 01-10-2007 04:02 AM
MS Server 2003 help nappyjim Off Topic 3 05-25-2006 05:22 PM
winxp crashed, can I repair with my home pc? cw42 Newbie 2 10-08-2005 04:01 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
