Old 08-31-2009, 07:57 AM   #121
boelle is an unknown quantity at this point
i'm going to use this one anyway, nothing beats it
but still i would love to have an option for using a server at my hosting company... my pc could crash and then all data is lost
but then when upload of photos is possible then i will quickly run out of space, i can upgrade my account but only up to a limit that i have forgotten
my idea are still to offer some kind of webservice for others, only need for someone to code the php or learn myself doing that. but for a webservice there has to be a limit (setable) for how much data is stored for each user.. one thought is the photo's, they need to be at around 10*15 cm and sharp.. but how much can you compress them without loosing to much info? they have to be able to be used as proff. the sql data do not take that much space it the photo's that concerns me
i have still not heard from webmaster but still his app did not offer the same as this plugin..
boelle is online now   Reply With Quote
Old 09-07-2009, 07:13 PM   #122
technostar's Avatar
technostar is an unknown quantity at this point
i'm trying this app to work on my car pc but i'm getting the error message below... any idea how to fix this?
9/7/2009 3:30:43 PM:Warning: Error caught while resending data :System.Data.SQLite.SQLiteException: SQLite error
no such column: transfered
at System.Data.SQLite.SQLite3.Prepare(SQLiteConnectio n cnn, String strSql, SQLiteStatement previous, UInt32 timeoutMS, String& strRemain)
at System.Data.SQLite.SQLiteCommand.BuildNextCommand( )
at System.Data.SQLite.SQLiteCommand.GetStatement(Int3 2 index)
at System.Data.SQLite.SQLiteDataReader.NextResult()
at System.Data.SQLite.SQLiteDataReader..ctor(SQLiteCo mmand cmd, CommandBehavior behave)
at System.Data.SQLite.SQLiteCommand.ExecuteReader(Com mandBehavior behavior)
at System.Data.SQLite.SQLiteCommand.ExecuteReader()
at WindowsApplication1.DatabaseProcessor.resendData(S tring filename, String user)
broom-broom-pc
m-atx:amd2600xp:512mb:40gb:m2-atx:roadrunner:lsxvoid
technostar is offline   Reply With Quote
Old 09-09-2009, 05:13 PM   #123
lambosprit's Avatar
lambosprit is on a distinguished road
my guess would be you've installed both the client and server on the same machine and same directory. The definition of the database tables is different even though the database file names are the same. Just uninstall and install the client first in one directory then the install again but this time the server in a different directory.
I presume your doing this for testing as the server should be on your home pc and the client on your car pc.
lambosprit is offline   Reply With Quote
Old 09-14-2009, 10:21 PM   #124
technostar's Avatar
lambo... thanks for the response, and that's exactly what i did earlier, i have installed server and client on one folder... i uninstalled it and did exactly what you told me and it's working fine now... once again, thanks for the great app....
broom-broom-pc
Old 09-22-2009, 05:55 PM   #125
lambosprit's Avatar
Version 3 comming v soon. Its now a service based server. Just doing some final testing.
Old 09-23-2009, 05:22 PM   #126
technostar's Avatar
that's awesome lambosprit... one more thing... i noticed that i get a .net error once in awhile and I don't know if the xport splitter is having an issue or what not... i just want to what is the best port splitter out there that you recommend for this app?
broom-broom-pc
Old 09-23-2009, 05:59 PM   #127
lambosprit's Avatar
I use xport and dont have a problem. Whats the error message?
Old 09-26-2009, 03:09 AM   #128
will v3 support upload of photos? and can it take more than one source.. ie taking photos from inside the car and the rear bumber cam? why this.. 1. to prove that thives where in the car... 2. extra proof of what route they took
3 cam sources should be enough for most situations
Old 09-27-2009, 05:20 PM   #129
lambosprit's Avatar
the answer is probably. Photo's will come if not in this version then the next but Tracker wont be able to take them. It will only be able to transfer them. The way it will work is some other program will create the picture in a set location. Tracker will check that location and send 1 picture to the server.It will then delete that picture.
So it is camera source independant BUT you will need software to create the photo's.
Old 09-28-2009, 03:10 AM   #130
could it be done so that it transfers all pictures in that location and then delete them? in case i set it up so that 3 pictures are taken, one pic from each source... or will the client basicly transfer pictures but one at a time?
Old 09-28-2009, 08:27 AM   #131
lambosprit's Avatar
there's only space for one photo at a time and I'm worried about the time required to upload a picture to the server. If you leave the photos there then the next time it sends data it would take the next one and so on until all photo's had been sent.
Old 09-28-2009, 03:51 PM   #132
well the photos have to have a minimum of quality or else they cant be used as proof... but i guess a pic of 500 kb is enough for most situations
Old 10-02-2009, 12:11 PM   #133
lambosprit's Avatar
managed to send my first picture today. I have an issue that it can only be a max of 64kb at the moment but still working on it.
Just a question to all the people using this. Whats the maximun screen size I could use. I have to add a picture box now and things are getting crowded on that screen. May have to start putting things in seperate screens soon.
Old 10-04-2009, 05:55 AM   #134
what about a small area that shows the last 10 pictures in a list form of some kind where you of course can select one of the last 10 pictures and a option in that list to selct more pictures that open a new window with all pictures?
Old 10-05-2009, 06:10 PM   #135
lambosprit's Avatar
Version 3 released - get it in the first post.
Quite nervous about this one as its a big change. Tried to do lots of testing but sure bugs have got through.
Also I hope everyone understands what we're trying to achieve with the new mapping feature. If you have any questions please ask.
it works.. auto syncing when you arrive home collegeboyslive General MP3Car Discussion 4 11-29-2007 07:36 PM
Home stasik-a4 Map Monkey 1 06-01-2007 01:55 AM
Image server qwertylol Software & Software Development 1 01-10-2007 04:02 AM
MS Server 2003 help nappyjim Off Topic 3 05-25-2006 05:22 PM
winxp crashed, can I repair with my home pc? cw42 Newbie 2 10-08-2005 04:01 PM
