Old 06-01-2009, 03:42 PM   #1
BazzaAlpine's Avatar
BazzaAlpine is an unknown quantity at this point
GPS problem when runing iGO8 through iGOzoomer_109
On it's own iGO8 is running fantastic. Finds the GPS with no problems. However when I try and run iGO_zoomer_109 (so it can run better in RR) iGO only seems to be able to search com port 1 for the GPS and mine defaults to 3.
I've manually added the GPS settings into sys_pc but that's not made any difference and I've tried doing a whole load of searches with no joy Anyone else had this problem and more importantly anyone know how to fix it? This is pretty much the last thing I need to get the front end working like I want it.
BazzaAlpine is offline   Reply With Quote
Old 06-01-2009, 04:43 PM   #2
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
RR is probably snatching the com port - are you using xport?
(assuming you're running IGO stand-alone outside RR)
treetop777 is offline   Reply With Quote
Old 06-01-2009, 09:58 PM   #3
roflcopter's Avatar
roflcopter is an unknown quantity at this point
make sure in your SYS_PC.txt file in your igo folder has
[gps]
port="3"
baud="9600"
set_messages="1"
not sure what the set_messages does but thats in mine.
i've found that igo is very unstable with igo_zoomer so i stopped using it and i just have the bottom of my screen cut off by a few pixels. i can't see my current location which kind of sucks, but what can you do? at least it doesnt crash any longer.
2007 Saab 9-3ss 2.0T
Jetway J7F5M1g5d-VHE-LF, 32gb patriot SSD, 160gb WD hdd, nLite XP sp3, EWF/Horm, RideRunner
Current Progress:
PC
HARDWARE [100%] SOFTWARE [95%] FABRICATION [100%] INSTALL [75%]
Workblog
roflcopter is offline   Reply With Quote
Old 06-02-2009, 04:00 AM   #4
Thanks roflcopter, I'll try those settings lunchtime. I have set messages="0" on mine and the rest is the same already.
Treetop777 Yes when it's working is when I run igo with out RR. Thing is I can run igo zoomer without running RR and it still does the same thing so I don't think it can be anything RR would do.
How to Embed any GPS program into Road Runner jonessc RR FAQ 52 10-28-2009 12:10 PM
holux 210 gps antenna problem Help please professorjason GPS 4 09-04-2005 01:38 PM
Beginning to go INSANE!!! *aaaaah* GPS problem t0ffluss GPS 8 12-31-2002 12:37 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
