Old 08-11-2009, 12:06 AM   #1
stewman is an unknown quantity at this point
Centrafuse won't recognise my USB SiRF III GPS Receiver
Hi, I am having a problem with Centrafuse 2.0, when I open navigation, it won't display any satellites of get a postition fix. I am using a USB SiRF III GPS Receiver from MoCoSo.
Here is what I have done so far:
- Installed the USB-Serial Driver
- Installed the GPSInfo program
- Run GPSInfo program- finds GPS reciever on Com Port 10 and baud 4800
- picks up satellites and fixes position instantly
Run Centrafuse - set Com Port to 10 and baud to 4800
- load Australian Map
and no signal.
The instructions for the GPS Reciever say to set baud to 57600 but when I do this, the GPSInfo program won't find the reciever at all. I tried all the above with the GPSInfo program opened and closed, with GPS running and not.
Has anyone had a similar problem? Thanks for your help, this forum is fantastic!
stewman is offline   Reply With Quote
Old 08-27-2009, 06:05 AM   #2
mrbean_phillip is on a distinguished road
Set the Comport in Device Manager to 9 or lower, and select same port in CF.
I have had a few instances of this, and are opting to use COM8 -works very well.
Your default baud is most likely 4800, protocol = NMEA
mrbean_phillip is offline   Reply With Quote
Question about USB powering of the GPS receiver. acura cl GPS 5 10-05-2006 05:45 PM
Earthmate GPS Receiver USB sesshoumaru562 Classified Archive 3 08-25-2004 12:36 PM
simple soft to test USB GPS receiver felix99 GPS 1 10-08-2002 03:23 PM
Got my Navman RandMcnally USB GPS NMEA 2.0 compliant receiver. LESLIEx317537 General Hardware Discussion 5 03-13-2002 03:54 PM
