Hm, what connector exactly is broken, and why do you think you 'really messed up'?. Did you fry your GPS, did you see smoke come out somewhere?
How did you end up doing the wiring, meaning, how did you match the wires to the pin?
Don't give up! If just the cable connector is broken I think this should be fixable.
As I said before, I would definitely try to unlock the device, you will be able to do much more things with it. Maybe run a music player, calculator, pdf viewer, depending on your processing power even run a video player, etc. Or run a different GPS software with better maps!
For unlocking Windows CE check out the link
here
It is not really 'beginner' friendly, but not to tricky ether. The problem is that your device is not so popular and you will not get easy step by step instructions.
Your device has 512MB internal flash memory, no SD card reader. It seems you can connect a USB thumb drive, which you will need if you want to unlock it and install another software.
Actually, mp3car.com is a car
pc forum, and people here don't like standalone navigation systems so much. You will not find a lot of information and help here on this topic.
It's not a personal thing, just that people here do different things (basically put a full-blown PC into their cars) and have different interests/knowhow.
Btw, I don't know why, but I just invested an hour to find out more about your device. I guess you are just lucky that these are my first posts on mp3car.com and I'm motivated
The device is a rebranded Plenio vxa-2000. It seems the manufacturer is
DVS, a Korean company. The homepage is
http://www.dvs.co.kr.
I actually found a
report where somebody ordered a replacement antenna by contacting
cs.dvs@dvs.co.kr.
There is a
long discussion on the VXA-3000 here, which might have some similiarities in terms of hardware/software used (it runs Windows CE 4.2).
One more thing, there are USB GPS devices out there for less than 30 USD, I definitely would not go with a 100 USD device.
Last advise: google more, and read more, you might not always be so lucky to find somebody do all the work for you
peace
