Old 04-01-2003, 12:03 PM   #1
samc's Avatar
samc
Copilot 2003 + rand mcnally gps wrong??
Hi I'm using a rand mcnally streetfinder gps antenna, and Copilot 2003. But this setup seems to give my wrong directions.
Ok the antenna is mounted in the back rear windshield.
When I'm going Copilot will tell me to "Turn righ on 82nd street"
But that street is a left turn only.
And when I turn at the next street, it will say I am at a different street. Is this just a poor antenna placement? or Copilot error?
Mine needs to be updated.
samc is offline   Reply With Quote
Old 04-01-2003, 12:18 PM   #2
ddt
Registered User
ddt's Avatar
ddt
I would say inaccurate directions from Copilot.
ddt is offline   Reply With Quote
Old 04-01-2003, 12:22 PM   #3
samc's Avatar
samc
ok so in general Copilot will always give me wrong directions?
Old 04-01-2003, 03:37 PM   #4
ddt
Registered User
ddt's Avatar
ddt
no... but I've run across the same thing a few times.. but not often.
Old 04-04-2003, 11:06 AM   #5
Raekwon
Keep us updated on the problem... I want to see how it turns out.
Raekwon is offline   Reply With Quote
Old 04-04-2003, 11:16 AM   #6
samc's Avatar
samc
well ok I just ordered db9 serial and ps/2 connector extenders. Hopefully if I place the gps antenna right under my front dash, it'll be good. Oh and I seem to get connections like within 30 seconds, on 4 different test.
Copilot in general does seem to get me from A to B but just not 100% efficient. Thats what you get for a $399 program
Old 04-04-2003, 11:22 AM   #7
Raekwon
What do you mean by under the front dash? You mean remove the instrument cluster and put it behind that? Good luck with the extensions.
BTW, does that GPS just plug into the USB and nothing else?
Old 04-04-2003, 11:28 AM   #8
samc's Avatar
samc
oops did I type under? I meant on my front left dash. Right next to the air vent. Thats directly under the windshield and would have a direct view of the sky, no tints.
And I have Copliot 2003 with the Rand McNally Gps receiver. The receiver uses serial db9 and ps/2 connector for the power (go figure)
check your PM raekwon
Old 04-04-2003, 04:28 PM   #9
Raekwon
That seems like a logical place to put it. PMs checked and double-checked.
