Old 10-04-2009, 03:22 PM   #1
diggla is an unknown quantity at this point
GPS issue
Replace my motherboard, brand new install everything went gd. Before my trip everything worked good. On the way up it started to act weird. I would be on the road i want to and the wayfinder would be off to the right and it said off road. Then after a while it would go back to the road i was on. Get to where I had to, shut the truck off and later on went out nav dont work. It shows no satellites, meanwhile nothing changed. I am using xport, USGlobsat BU 353 GPS receiver, and Iguidance. MY previous motherboard setup worked great no issue. Now all of the sudden I have this. The receiver goes directly into the usb on the motherboard. I tried to re-install the drivers, restart the machine but nothing. In xport it shows the gps and bit rate. When I open iguidance itself from desktop and have it search com port for GPS it finds it but no satellites. Any ideas?
Drew
diggla is offline   Reply With Quote
Old 10-04-2009, 03:42 PM   #2
North of the land of Hey Huns
malcom2073's Avatar
malcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to all
Try running iGuidance without xport, see if it works. I have the exact same symptoms sometimes when running xport.
RevFE - Try it, you just might like it.
Carbon - Next Generation Touchscreen Browser
Come join us on IRC: irc.efnet.net #mp3car
Audiophiles make me chuckle as they pad my wallet.
malcom2073 is offline   Reply With Quote
Old 10-04-2009, 06:03 PM   #3
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
try a different usb port
Intel D945GCLF2 Dual Core ATOM
Lilliput 7" 629GL 2008 LED Backlight
BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
M2-ATX Power Supply
RideRunner Front End / Various Skins
Windows XP SP3
treetop777 is offline   Reply With Quote
Old 10-04-2009, 07:24 PM   #4
ran it without xport, tried different usb hubs. Even hooked up my laptop which I know worked cause I used it last weekend and still no signal. Think its the receiver, whats weird is its in a good spot never touched. I'll order a new one, think im gonna go with one that has the wifi as well. What do you guys recommend?
Old 10-04-2009, 08:03 PM   #5
Raw Wave
treetop777's Avatar
Zap it! But read this first: http://www.mp3car.com/vbulletin/gps/...u-353-lag.html
M2-ATX Power Supply
Windows XP SP3
Old 10-04-2009, 08:52 PM   #6
kewl, i'll play around with that tomorrow. thx
Old 10-04-2009, 10:21 PM   #7
What can I say? I like serial.
Curiosity's Avatar
Curiosity will become famous soon enough
I've been working on xport to show less cryptic information at the bottom, but I can gaurantee the GPS doesn't get better or worse reception with xport. The only time people are fiddling with it is when they have poor reception that takes random amounts of time to lock.
You should log some data and look at it afterwards and try to find any differences between the good periods and bad. You could see corrupt data, short sentences with lots of ,,,, in them or missing sentences (i.e no $GPGGA, $GPGSA), but most likely it's reception. In iGuidance go to View->GPS Info. Look at the little bars on the bottom that are moving up and down. If you don't see those, you have a problem.
I just bought a used BU-359 off ebay and it only had GPVTG. Started up Sirfdemo and selected what I wanted and it worked great. But I've never seen a GPS change settings without manually changing them.
XPort 1.41 -GPS port splitter, logger, and USB device resume fix
GPS DirectShow Filter / XOBD / MiniCam
Curiosity is offline   Reply With Quote
Old 10-05-2009, 07:25 AM   #8
during the trip there was no satellites when the problem occurred. now I get 2 satellites and they are low. The position of the receiver has not changed in over a year.
Old 10-05-2009, 08:25 AM   #9
Curiosity's Avatar
That's not good. You sure you haven't added anything electronic near it? Even though the position hasn't changed, you should try moving it to see if things improve. Then as a last resort use SirfDemo. Switch to sirf then back to NMEA.
Old 10-05-2009, 08:06 PM   #10
so here is the verdict, hooked up the gps to my laptop again got no signal. Opend sirfdemo played around and all of the sudden got signal. Think i save a couple of logs will post later. Gps is working, will hook it back up to carpc and see what happens. Did all of this without removing it from the car
Old 10-06-2009, 06:02 PM   #11
cant get it to work in the truck so gonna go buy a new one, just total bs.
Old 10-07-2009, 10:11 AM   #12
well got anoyed decided to pull the receiver out and just for fun stuck it on my roof and what do ya know got signal lol. dont get it, worked perfectly for a year in the dash. will keep a eye on it to see if it goes back
Old 10-07-2009, 11:07 AM   #13
Curiosity's Avatar
Are you getting at least 8-10 pretty strong? I would think so. Just try some different spots. Fall equinox has moved the sats lower in orbit. Uhm... Make sure it's facing up and not under anything metal. Maybe just on top of the dash if nothing else.
Old 10-07-2009, 01:11 PM   #14
i get about 5
Old 10-12-2009, 09:20 AM   #15
mounted the unit outside the truck and now get perfect signal, 8-9 satellites. Works like a charm.
Bluetooth GPS connection issue - 1.1.0.0 Sinabl StreetDeck Bug Reports 5 12-14-2007 10:36 AM
Earthmate GPS Reciever Com Port issue in Map Monkey aseraj Map Monkey 3 03-31-2005 07:17 AM
GPS issue with MediaCar Jemmi MediaCar 1 08-12-2004 04:08 PM
MediaCar GPS issue kingmissel MediaCar 0 07-13-2004 05:47 PM
